Product Enhancements
Jamf Connect Configuration 1.7.0 – Configuration Storage: You can now save and edit configurations within the Jamf Connect Configuration app. Saved configurations are displayed in a sidebar on the left side of the window.
Jamf Connect Login 1.9.0: You can now configure the opacity of the background image alpha channel with the BackgroundImageAlpha preference key.
Bug Fixes
Jamf Connect Sync 1.2.2:
• [PI-007242] Fixed an issue that caused Jamf Connect Sync to fail to display security question multifactor authentication (MFA) prompts to users.
• [PI-007772] Fixed an issue that caused Jamf Connect Sync to display an incorrect message to users with a one-time password (OTP) as their only MFA method.
• [PI-007808] Fixed an issue that caused Jamf Connect Sync to blank out the password field of the login window when attempting to complete SMS multifactor authentication, preventing successful login.
Product Documentation
For more information, including Release Notes, please see the Jamf Connect Administrator Guide.
