macOS patch report
  • August 6, 2019
  • 13 views
Hey,
in Jamf Pro's macOS Patch Reporting only the latest mojave version (10.14.6) is marked as "latest version". If I look at 10.13.6 it's marked in red as "other version"
I wonder if it's possible to also mark e.g. 10.13.6 and 10.12.6 as "latest version" as they are up to date and have the latest security features.
Best answer by sdagley
@leonwun Not all of the security fixes added to 10.14.x get back ported to 10.13x or 10.12.x. If you rally want to be fully patched, or as fully patched as you can get, then 10.14.6 is the version of macOS you want to be at.
sdagley
  • August 6, 2019
  • August 7, 2019
Okay thanks for your input, still our IT-Security Team approves of 10.xx.6 versions so it would be great if someone knows a solution.
