Is there anyway to have a multi-line message? I am trying to have a user click on a button in self service and display things like computer name / username / mac address / IP address for our service desk staff and I can get one line to show but no more. Really don't want them to have to click multiple self service buttons.
This is the script that I use for this, you may need to edit it if you have a bunch of newer machines that only have wireless.
#en0Address=`ifconfig en0 | grep "inet" | cut -d " " -f2`
en1Status=`ifconfig en1 | tr ' ' '
' | grep "active"`
en0Status=`ifconfig en0 | tr ' ' '
' | grep "active"`
CurrentUser=`who | grep "console" | awk '{print $1}'`
hostnamename=`hostname | cut -d "." -f 1`
computername=`jamf getComputerName | cut -d ">" -f2 | cut -d "<" -f1`
OSVersion=`sw_vers | grep "ProductVersion" | awk '{print $2}'`
en1MACAddress=`ifconfig en1 | grep "ether" | cut -d" " -f2`
en0MACAddress=`ifconfig en0 | grep "ether" | cut -d" " -f2`
TotalRam=`system_profiler SPHardwareDataType | grep "Memory:" | cut -d":" -f2`
BootVolume=`system_profiler SPSoftwareDataType | grep "Boot Volume:" | cut -d":" -f2`
TotalBootDriveSize=`system_profiler SPSerialATADataType | grep "$BootVolume" -A2 | grep "Capacity:" | cut -d ":" -f2 | cut -d "(" -f1`
AvailBootDriveSize=`system_profiler SPSerialATADataType | grep "$BootVolume" -A2 | grep "Available:" | cut -d ":" -f2 | cut -d "(" -f1`
if [ "$en1Status" == "active" ];
    then en1Address=`ifconfig en1 | grep "inet " | cut -d " " -f2`
    else en1Address="not active"
if [ "$en0Status" == "active" ];
    then en0Address=`ifconfig en0 | grep "inet" | cut -d " " -f2`
    else en0Address="not active"
jamf displayMessage -message "Wired address is $en0Address
Wireless address is $en1Address
Current Logged on user is $CurrentUser
Computer name is $computername
Hostname is $hostnamename
OS version is $OSVersion
Wired MAC Address is $en0MACAddress
Wireless MAC Address is $en1MACAddress
Total RAM (Memory):$TotalRam
Boot Volume:$BootVolume
    Total size:$TotalBootDriveSize
    Free space:$AvailBootDriveSize"
@rlandgraf Well that was incredibly helpful! Thanks!
Very handy! Though I'm not getting results for the Total size and free space. Love having easy access to the MAC addresses, though.
I also like to toss in the serial number for quick warranty status checks. Definitely not a necessary addition though.
SerialNumber=`system_profiler SPHardwareDataType | grep Serial | awk '{ print $4 }'`
Serial Number is $SerialNumber"
Here is a cocoaDialog version:
' | grep "active"`
' | grep "active"`
/path/to/cocoaDialog.app/Contents/MacOS/cocoaDialog msgbox
--title "" --text "Your Computer Info"
--informative-text "Wired address is $en0Address
- Total size:$TotalBootDriveSize
- Free space:$AvailBootDriveSize" --button1 "OK" --quiet
Though admittedly I'm getting mixed results on my Retina Pro hooked up to a Thunderbolt display, since the display's ethernet is apparently en7. I'm guessing the above is designed for MBP 2012 and earlier?
@emilykausalik Yeah I wrote this some time ago for machines that had ethernet and wifi as en0 and en1. The logic would have to be added in to better figure out which ports are which. We are running mostly older MacBooks here so I hadn't really needed to update.
I took this and made some changes to get it to display simplified info for my users to give us.
The only way i could get HD capacity and availability is to use SPStorageDataType but it does add the benefit of offering external drive info as well
as for the IP i am just grepping anything that is " active" in ifconfig and pulling the IP.. may be an issue if multiple IPs are on our devices but will also let us know if a user has turned on wifi somehow.
@emilykausalik My around the way method for IP should work on your MacBook Pro too
#A script to display info for the mac
IPAddress=`ifconfig | grep " active" -B3 | grep "inet " | cut -d " " -f2`
TotalBootDriveSize=`system_profiler SPStorageDataType | grep "Capacity:" | cut -d ":" -f2 | cut -d "(" -f1`
AvailBootDriveSize=`system_profiler SPStorageDataType | grep "Available:" | cut -d ":" -f2 | cut -d "(" -f1`
jamf displayMessage -message "IP Address is $IPAddress
A nice way to get the active interface ie en0 or en1 or whatever and then get the IP address for it
active_interface=`route get www.apple.com | awk '/interface/ { print $2 }'`
my_ip_address=`ipconfig getifaddr $active_interface`
echo "My Active (Primary) interface is: ${active_interface}."
echo "My Active (Primary) IP Address is: ${my_ip_address}."
I've updated to reflect info we wanted:
IPAddress=`ifconfig | grep " active" -B3 | grep "inet " | cut -d " " -f2 | tr '
AvailBootDriveSize=`system_profiler SPStorageDataType | grep "Available:" | cut -d ":" -f2 | cut -d "(" -f1 | head -1`
localmac=$(system_profiler SPHardwareDataType | awk '/Serial/ {print $4}' | cut -c 9-)
curldata=$(curl -s https://support-sp.apple.com/sp/product?cc=$localmac| sed 's|.*<configCode>(.*)</configCode>.*|1|')
ssid=$(/System/Library/PrivateFrameworks/Apple80211.framework/Versions/Current/Resources/airport -I | grep SSID: | sed "1 d" |  cut -f2 -d$':' | cut -d ' ' -f 2)
FED2=`fdesetup status | grep is | tr -d 'FileVault is ' | tr -d '.'`
if [ "$FED2" == "" ]; then
fv="Off"
fv="On"
jamf displayMessage -message "IP Address(es) is $IPAddress
WiFi SSID: $ssid
FileVault = $fv
Mac Model: $curldata
Jamf has posted a Build a Computer Information script for your Help Desk here;
https://www.jamf.com/blog/build-a-computer-information-script-for-your-help-desk/
