.pkg greyed out in Disk Utility - Image from folder
  • July 23, 2017
  • 37 views
Hello Everyone,
I'm trying to create a .dmg from a .pkg, but when I use Disk Utility - Image from Folder I can't select any .pkg. They are all greyed out.
Any advice on what I might be doing wrong.
Thanks, James
Best answer by donmontalvo
[Edit] Misunderstood, you're creating, not saving the DMG. I ran a quick test, am able to replicate the issue. Created a blank file, and created an empty folder, both with *.PKG suffix. Disk Utility ignores both. TBH whenever I create a DMG from a PKG, I always create an enclosing folder first.
$ touch ~/Desktop/TRASHME/testFile,pkg
$ mkdir ~/Desktop/TRASHME/testFolder.pkg
$ ls -lF ~/Desktop/TRASHME/
total 0
-rw-r--r--  1 donmontalvo  staff   0 Jul 22 21:59 testFile,pkg
drwxr-xr-x  2 donmontalvo  staff  68 Jul 22 21:59 testFolder.pkg/
Disk Utility ignores both:
donmontalvo
Forum|alt.badge.img+36
  • July 23, 2017
total 0
sdagley
  • July 23, 2017
@jpadilla Are you trying to create a .dmg of a .pkg so you can deploy it with Jamf Pro? Can you not just deploy the .pkg file itself? If you really need the .pkg encapsulated in a .dmg, put the .pkg into a folder, the select that folder as the folder to create the .dmg from rather than the .pkg file itself. Or use the Composer app (one of the tools in the Casper Suite folder) to create the .dmg
  • July 23, 2017
@donmontalvo @sdagley Thank You! Enclosing in folder worked for me.
