Anyone using Impulse/SafeConnect for their NAC? Need help getting Apple’s device activation/Jamf working
  • August 7, 2019
  • 9 views
Hi everybody. We’re using Impulse/SafeConnect for our network access control, and we’re trying to open the right ports and IP addresses to allow our iPads to connect to Apple, activate, then get our configuration profile from our Jamf instance.
We opened up Apple’s IP range, which gets the device past the activation phase, but it just shows “canceled” when trying to install the Jamf configuration profile. Any tips?
1 reply
  • June 8, 2020
We're in the same boat. Did you happen to ever learn anything?
