I'm running into difficulty packaging the OSX Lion files in a way that allows me to customize the install.
With 10.6.3, when I import the DMG of the installer media, Casper Admin would:
1) recognize it: https://skitch.com/davidkoff/eryhq/10.6.3-disc
2) and allow me to customize it: https://skitch.com/davidkoff/eryhs/10.6.3-customizers
With 10.7.4, when I import the InstallESD.dmg, Casper Admin will:
1) recognizes it in an identical way as it had with 10.6.3
2) but will NOT allow for customization: https://skitch.com/davidkoff/ery51/lion-fail
Anyone got a way around this? And I know... There's already a bunch of info on this topic over at: https://jamfnation.jamfsoftware.com/article.html?id=173. But I'm not getting what I need from that thread. Which is a bummer maximus...
My goal is to be able to run a 10.7.4 installation over machines that already have 10.6.8 installed": effectively an upgrade-in-place. No wiping the drive, no installing a new custom image, just installing Lion. Dig?
Cheers n' tanks,
DK
have you tried this?
http://managingosx.wordpress.com/2011/09/06/automated-installs-of-mac-os-x-lion/
check the treads here for details using this with self service.
