According to the Admin Guide doco (10.14) as well as the Jamf Remote app, it looks like the script options in Jamf Remote still has Parameter 1 to 8.
I think these parameters should be from 4 to 11 same as Parameter Labels in the jss web console.
@ccsben You should file this as a Feature Request as that's a better way to report a flaw than a discussion thread.
