Hi All,
If I install the Package on the Desktop manually this works fine.
Via Capser I get the following message.
Any idea? What is the best way to install Adobe CC2015?
Installation failed. The installer reported: installer: Package name is Adobe CC 2015
installer: Installing at base path /
installer: The install failed (The Installer encountered an error that caused the installation to fail. Contact the software manufacturer for assistance.)
Thanks
Mitch
