Modifying pre-filled username in PreStage Enrollment
  • February 6, 2020
  • 28 views
If I'm using "Pre-fill primary account information" in a PreStage Enrollment to create the user's account, is there a way to modify the username? I'd like to drop the domain part of their username rather than ending up with user@domain.tld as their computer account's shortname. I see there's a custom setting but can it use any kind of variable or script in there?
Forum|alt.badge.img+23
Take a look at Jamf Pro 10.19 beta for things like that. ; )
  • February 6, 2020
Good to know! Is there a link with any details or do I need to request access to the beta?
I am looking to do this exact same thing. Did you ever get this working?
