I want to give a user group a permission to enable/disable Bluetooth on individual devices (iOS) via remote command.
These members have the button that shows up on their UI when they login, all other remote command buttons work such "update inventory" "clear passcode" "wipe device," etc...
I went into the group, added the permission and the bluetooth button does not work.
It works with my permissions, from my machine. It does not work on his machine or any other machine with different browsers, etc..
Am I missing something or is it just a bug?
Be the first to reply!
