IKEv2 VPN StrongSwan - Always on
  • May 10, 2018
  • 0 replies
  • 9 views
Hi Guys,
Need some help...
We have a StrongSwan VPN server setup and are ready to implement it on our iPhones as an Always On VPN Solution. Firstly, we have tested this by putting the VPN configuration onto Jamf and deploying this to the phone (without the Always ON ticked) and it works perfectly, we simply switch the VPN on on the iPhone and WALAH!.
HOWEVER, on that same config, we select 'Always ON' feature on the same config and the VPN just spirals into a loop.
All phones are supervised...
I've had a ticket open for nearly a week now with Jamf but to no avail as of yet.
Wondering if anyone else has had this issue? And what is the answer?! :O
Thanks,
Andrew
