Remove Web Clips iOS
  • February 7, 2020
  • 7 replies
  • 148 views
jbisgett
Is there a way to remove web clips that have been created by users via an mdm command/profile?
My issue is we have locked our student iPads so that they cannot remove apps from their devices, primarily so that they can't delete our filtering app. However, they still have the ability to create web clips, so some of our students have cluttered their iPads with web clips that now cannot be removed, since the profile treats web clips like apps.
I know I could just hide the web clips, so that they couldn't be seen by the students, but then this would hide any of the web clips that we have specifically pushed out.
I would really like to be able to send a command to remove web clips from a device, then have our district web clips just be resent to the device.
Also, is there a way to restrict web clips being created on the device? Remove the "Send to Home Screen" option"
  • September 24, 2020
Same issue here ...
Would like to restrict the "Send to Home Screen"-Option in Safari...
  • September 23, 2021
Same problem here, is there any update on this?
  • October 17, 2022
Was there ever a solution to this? Having the same problem.
maortiz
  • June 19, 2023
Same Issue here, looking for an update. I'm having to disable the profile containing layout restrictions to remove the webclip from the iPad, then enable restrictions again.
chrisandrews
  • December 14, 2023
Same issue here, any updates?
either the ability to use layout config but and app not listed can be moved/deleted/removed to app library, or to restrict the option in Safari to begin with.
  • January 29, 2024
Same Issue here, any updates?
  • November 6, 2024
Any solution to disabling the addition of web clips to the homepage by the user?
