Updating existing install package
  • March 2, 2019
  • 71 views
I have recently been assigned the role of Jamf administrator since the departure of the previous admin. I've been trying to catch up since very little was documented about the processes they had developed.
I'm trying to add an additional driver for a printer installation to support the new Mac Mojave OS. I have downloaded the proper driver from the vendor, but I can't figure out how to apply it to the already present install package. (I would like to avoid, if at all possible, creating a new install package so as to not have to re-educate my user base and re-write existing documentation.)
Any advice/suggestions would be greatly appreciated.
  • March 2, 2019
Hi there. Are you talking about an actual package installer, like a file with a .pkg extension on it? If so, there aren't really any ways to easily add in some other files without repackaging it. But repackaging it could be as simple as pulling the .pkg into Composer and converting it to a source, adding what you need to it, and then rebuilding it as a new .pkg installer. There are also some command line ways to adjust packages, but that's probably unnecessary to go into. You can use the same name as it had before for the package name.
if OTOH, you meant how to add something into a policy that installs this package, adding extra packages to those is easy. Just go into the policy, edit it and under the Packages section on the left, click the + button to select another package to add. You will have to make sure the package is added to your repository first of course. You can have more than one package in a policy.
In the latter case, the policy name would remain the same, and end users, assuming they are installing this from Self Service, would not know anything has been changed or added to it. It wasn't clear if that's what you meant by not wanting to retrain your user base or not.
  • March 19, 2019
Thanks MM2270. That is excellent information. The second scenario you mention - adding something to the policy - should do the trick. I appreciate the information.
