Hi all,
when installing a printer in Sierra using
/usr/sbin/lpadmin -p MyGreatPrinter -E -v lpd://my.print.server/print_queue_1 -P /path/to/PPD -o SomePPDOption=true
everything looks and works fine.
However, when adding a second printer with
/usr/sbin/lpadmin -p MyOtherPrinter -E -v lpd://my.print.server/print_queue_2 -P /path/to/PPD -o SomePPDOption=false
Sierra will use the same value for "SomePPDOption", even though they are set to different values.
Imagine you install one "Duplex" and one "Simplex" printer, it will always use the duplex setting for all installed printers.
When looking at the setting with
lpoptions -p MyGreatPrinter -l
the values are correct though.
This doesn't happen in 10.11 and earlier.
Anyone else seeing this?
EDIT: I should add that it only starts behaving wrong after you have actually printed to one of the queues.
Be the first to reply!
