Kaspersky on Mojave
  • March 4, 2019
  • 28 views
Has anyone had any luck getting Kaspersky to install via policy on Mojave? I was able to get kesmac 10.2.0.267 for High Sierra to work just fine. But using the same method for kesmac 10.2.1.319B it does install but Kaspersky unexpectedly quits when you try to launch it after install.
Best answer by Monkeyfist
I upgraded to Kaspersky 11 and things worked using the older way you can find searching on Jamf Nation.
dsavageED
  • March 5, 2019
At a guess this will be an issue relating to KEXTs (Approved Kernel Extensions) or PPPC (Privacy Preferences Policy Control) which can be remediated using configuration profiles. If it isn't either of these then perhaps Kaspersky is falling fowl of SIP, this though seems unlikely.
We use Sophos and do need both types of config to get it working on Mojave.
  • September 20, 2019
