Script to Install & Update Zoom
  • September 28, 2018
  • 142 replies
  • 1031 views
We use Zoom a lot, so I modified a script that we were using for Firefox (Thanks Joe Farage!) to install or update to the newest version of Zoom. This one enables HD video, sets SSO logins to be default, and configures the URL for SSO. Below is the script:
# ABOUT THIS PROGRAM
# NAME
#       ZoomInstall.sh -- Installs or updates Zoom
# SYNOPSIS
#       sudo ZoomInstall.sh
# HISTORY
#       Version: 1.0
#       - Shannon Johnson, 28.9.2018
#       (Adapted from the FirefoxInstall.sh script by Joe Farage, 18.03.2015)
# Script to download and install Zoom.
# Only works on Intel systems.
# Set preferences - set to anything besides "true" to disable
hdvideo="true"
ssodefault="true"
ssohost="psu.zoom.us"
# choose language (en-US, fr, de)
lang=""
# CHECK TO SEE IF A VALUE WAS PASSED IN PARAMETER 1 AND, IF SO, ASSIGN TO "lang"
if [ "$4" != "" ] && [ "$lang" == "" ]; then
        lang=$4
        lang="en-US"
pkgfile="ZoomInstallerIT.pkg"
plistfile="us.zoom.config.plist"
logfile="/Library/Logs/ZoomInstallScript.log"
# Are we running on Intel?
if [ '`/usr/bin/uname -p`'="i386" -o '`/usr/bin/uname -p`'="x86_64" ]; then
        ## Get OS version and adjust for use with the URL string
        OSvers_URL=$( sw_vers -productVersion | sed 's/[.]/_/g' )
        ## Set the User Agent string for use with curl
        userAgent="Mozilla/5.0 (Macintosh; Intel Mac OS X ${OSvers_URL}) AppleWebKit/535.6.2 (KHTML, like Gecko) Version/5.2 Safari/535.6.2"
        # Get the latest version of Reader available from Zoom page.
        latestver=`/usr/bin/curl -s -A "$userAgent" https://zoom.us/download | grep 'ZoomInstallerIT.pkg' | awk -F'/' '{print $3}'`
        echo "Latest Version is: $latestver"
        # Get the version number of the currently-installed Zoom, if any.
        if [ -e "/Applications/zoom.us.app" ]; then
                currentinstalledver=`/usr/bin/defaults read /Applications/zoom.us.app/Contents/Info CFBundleShortVersionString`
                echo "Current installed version is: $currentinstalledver"
                if [ ${latestver} = ${currentinstalledver} ]; then
                        echo "Zoom is current. Exiting"
                currentinstalledver="none"
                echo "Zoom is not installed"
        url="https://zoom.us/client/${latestver}/ZoomInstallerIT.pkg"
        echo "Latest version of the URL is: $url"
        echo "`date`: Download URL: $url" >> ${logfile}
        # Compare the two versions, if they are different or Zoom is not present then download and install the new version.
        if [ "${currentinstalledver}" != "${latestver}" ]; then
                # Construct the plist file for preferences
                echo "<?xml version="1.0" encoding="UTF-8"?>
                 <plist version="1.0">
                 <dict>
                        <key>nogoogle</key>
                        <string>1</string>
                        <key>nofacebook</key>
                        <string>1</string>
                        <key>ZDisableVideo</key>
                        <true/>
                        <key>ZAutoJoinVoip</key>
                        <true/>
                        <key>ZDualMonitorOn</key>
                        <true/>" >> /tmp/${plistfile}
                if [ "${ssohost}" != "" ]; then
                        echo "
                        <key>ZAutoSSOLogin</key>
                        <true/>
                        <key>ZSSOHost</key>
                        <string>$ssohost</string>" >> /tmp/${plistfile}
                echo "<key>ZAutoFullScreenWhenViewShare</key>
                        <true/>
                        <key>ZAutoFitWhenViewShare</key>
                if [ "${hdvideo}" == "true" ]; then
                        echo "<key>ZUse720PByDefault</key>
                        <false/>" >> /tmp/${plistfile}
                echo "<key>ZRemoteControlAllApp</key>
                        <true/>
                </dict>
                </plist>" >> /tmp/${plistfile}
                # Download and install new version
                /bin/echo "`date`: Current Zoom version: ${currentinstalledver}" >> ${logfile}
                /bin/echo "`date`: Available Zoom version: ${latestver}" >> ${logfile}
                /bin/echo "`date`: Downloading newer version." >> ${logfile}
                /usr/bin/curl -L -o /tmp/${pkgfile} ${url}
                /bin/echo "`date`: Installing PKG..." >> ${logfile}
                /usr/sbin/installer -allowUntrusted -pkg /tmp/${pkgfile} -target /
                /bin/sleep 10
                /bin/echo "`date`: Deleting downloaded PKG." >> ${logfile}
                /bin/rm /tmp/${pkgfile}
                #double check to see if the new version got updated
                newlyinstalledver=`/usr/bin/defaults read /Applications/zoom.us.app/Contents/Info CFBundleShortVersionString`
        if [ "${latestver}" = "${newlyinstalledver}" ]; then
                /bin/echo "`date`: SUCCESS: Zoom has been updated to version ${newlyinstalledver}" >> ${logfile}
                # /Library/Application Support/JAMF/bin/jamfHelper.app/Contents/MacOS/jamfHelper -windowType hud -title "Zoom Installed" -description "Zoom has been updated." &
                /bin/echo "`date`: ERROR: Zoom update unsuccessful, version remains at ${currentinstalledver}." >> ${logfile}
                /bin/echo "--" >> ${logfile}
                        exit 1
        # If Zoom is up to date already, just log it and exit.
                /bin/echo "`date`: Zoom is already up to date, running ${currentinstalledver}." >> ${logfile}
        /bin/echo "`date`: ERROR: This script is for Intel Macs only." >> ${logfile}
Tested this script and has worked fine. Autopkg has been having an issue with the Zoom recipe recently, so I may just start using the script for the near future.
  • November 22, 2018
Works great, thank you!!!
  • November 29, 2018
While this script works perfectly for updating, for some reason Zoom hangs on the login screen when re-opening. If you close the window and open it again it's fine though. Anyone else running into this?
  • December 4, 2018
This script is great! Thank you!
  • February 19, 2019
@landono I am running into this as well. Are you using SAML SSO, if so who is your IdP?
I did another review of the script, and appears the plist is not being moved from /tmp/ to where it should be?
Edit NVM. Not sure why single sign on options are not working as intended using SAML.
  • May 30, 2019
Wonderful script!
I've been looking into setting audio output options for Zoom. For some reason, Zoom seems to ignore my device outputs, even if I set the output by hand. I've looked into setting outputs by switchaudiosource, and it while it does set the output on the device, Zoom doesn't respect the setting.
I also browsed through the plist configuration options here: https://support.zoom.us/hc/en-us/articles/115001799006-Mass-Deployment-with-Preconfigured-Settings-for-Mac
While there were a lot of good settings there, I didn't see anything about setting a default audio output. Has anyone been able to set audio output, and have zoom respect that, and keep the setting?
  • July 2, 2019
hmm, I've tried using this but the install errors out when installing via self service. Seems to work ok when trying to run via terminal.
Anyone else running into issues? this is with both High sierra and mojave.
  • July 2, 2019
I package the following preinstall and postinstall scripts in a payload-free package using Packages app. Hope it helps.
[PREINSTALL]
zoom_plist="/Library/Preferences/us.zoom.config.plist"
sleep 0.5; echo "info: finding and removing old temp folders"
find /private/tmp -maxdepth 1 -type d -name "com.example.zoom_tmp.*" -exec rm -rf {} ;
sleep 0.5; echo "info: making new temp folder"
zoom_tmp=$(mktemp -d /private/tmp/com.example.zoom_tmp.XXXX)
sleep 0.5; echo "info: temp folder is ${zoom_tmp}"
echo "${zoom_tmp}" > "${zoom_tmp}/zoom_folder.tmp"
sleep 0.5; echo "info: checking if zoom is running"
pgrep zoom.us >/dev/null
if [[ "$?" = "0" ]]; then
  sleep 0.5; echo "info: zoom is running"
  zoom_running="YES"; echo "YES" >  "${zoom_tmp}/zoom_running.tmp"
  sleep 0.5; echo "info: quitting zoom now"
  pkill zoom.us
  sleep 0.5; echo "info: zoom is not running"
  zoom_running="NO"; echo "NO" >  "${zoom_tmp}/zoom_running.tmp"
sleep 0.5; echo "info: looking for zoom plist"
if [[ -e "${zoom_plist}" ]]; then
  sleep 0.5; echo "info: zoom plist already exists"
  sleep 0.5; echo "info: zoom plist was not found"
  sleep 0.5; echo "info: creating zoom plist now"
  touch "${zoom_plist}"
sleep 0.5; echo "info: setting ZAutoSSOLogin to true"
defaults write "${zoom_plist}" ZAutoSSOLogin -bool true
sleep 0.5; echo "info: setting ZSSOHost to cmu.zoom.us"
defaults write "${zoom_plist}" ZSSOHost -string "example.zoom.us"
sleep 0.5; echo "info: setting nogoogle to false"
defaults write "${zoom_plist}" nogoogle -string "1"
sleep 0.5; echo "info: setting nofacebook to false"
defaults write "${zoom_plist}" nofacebook -string "1"
sleep 0.5; echo "info: setting DisableLoginWithEmail to true"
defaults write "${zoom_plist}" DisableLoginWithEmail -string "0"
sleep 0.5; echo "info: setting AddFWException to false"
defaults write "${zoom_plist}" AddFWException -bool false
sleep 0.5; echo "info: setting LastLoginType to false"
defaults write "${zoom_plist}" LastLoginType -bool false
sleep 0.5; echo "info: setting ZAutoUpdate to true"
defaults write "${zoom_plist}" ZAutoUpdate -bool true
sleep 0.5; echo "info: setting ZDisableVideo to true"
defaults write "${zoom_plist}" ZDisableVideo -bool true
sleep 0.5; echo "info: setting ZAutoJoinVoip to false"
defaults write "${zoom_plist}" ZAutoJoinVoip -bool false
sleep 0.5; echo "info: setting ZDualMonitorOn to false"
defaults write "${zoom_plist}" ZDualMonitorOn -bool false
sleep 0.5; echo "info: setting ZAutoFullScreenWhenViewShare to true"
defaults write "${zoom_plist}" ZAutoFullScreenWhenViewShare -bool true
sleep 0.5; echo "info: setting ZAutoFitWhenViewShare to true"
defaults write "${zoom_plist}" ZAutoFitWhenViewShare -bool true
sleep 0.5; echo "info: setting FullScreenWhenJoin to false"
defaults write "${zoom_plist}" FullScreenWhenJoin -bool false
sleep 0.5; echo "info: setting AutoHideToolbar to true"
defaults write "${zoom_plist}" AutoHideToolbar -bool true
sleep 0.5; echo "info: setting ZUse720PByDefault to true"
defaults write "${zoom_plist}" ZUse720PByDefault -bool true
sleep 0.5; echo "info: setting ZRemoteControllAllApp to true"
defaults write "${zoom_plist}" ZRemoteControllAllApp -bool true
sleep 0.5; echo "info: setting ZHideNoVideoUser to false"
defaults write "${zoom_plist}" ZHideNoVideoUser -bool false
sleep 0.5; echo "info: setting MuteVoipWhenJoin to true"
defaults write "${zoom_plist}" MuteVoipWhenJoin -bool true
sleep 0.5; echo "info: setting ShowConnectedTime to true"
defaults write "${zoom_plist}" ShowConnectedTime -bool true
sleep 0.5; echo "info: setting ConfirmWhenLeave to true"
defaults write "${zoom_plist}" ConfirmWhenLeave -bool true
sleep 0.5; echo "info: setting DisableScreenShare to true"
defaults write "${zoom_plist}" DisableScreenShare -bool true
sleep 0.5; echo "info: setting EnableMirrorEffect to false"
defaults write "${zoom_plist}" EnableMirrorEffect -bool false
sleep 0.5; echo "info: setting DisableLinkPreviewInChat to true"
defaults write "${zoom_plist}" DisableLinkPreviewInChat -bool true
sleep 0.5; echo "info: all settings have been applied"
sleep 0.5; echo "info: moving to post install now"
sleep 0.5; echo "info: exiting pre install"
[POSTINSTALL]
zoom_tmp=$(find /private/tmp -type f -name "zoom_folder.tmp" -maxdepth 2 -exec cat {} ;)
sleep 0.5; echo "info: zoom temp folder is? ${zoom_tmp}"
zoom_running=$(find /private/tmp -type f -name "zoom_running.tmp" -maxdepth 2 -exec cat {} ;)
sleep 0.5; echo "info: was zoom running? ${zoom_running}"
zoom_url="https://zoom.us/client/latest/ZoomInstallerIT.pkg"
sleep 0.5; echo "info: downloading zoom installer package"
curl "${zoom_url}" -o "${zoom_tmp}/com.example.zoom.us.pkg" --progress
sleep 0.5; echo "info: running zoom installer package"
installer -pkg "${zoom_tmp}/com.example.zoom.us.pkg" -target LocalSystem
sleep 0.5; echo "info: removing temp directory ${zoom_tmp}"
rm -rf "${zoom_tmp}"
sleep 0.5; echo "info: does zoom need to launch?"
if [[ "${zoom_running}" == "YES" ]]; then
  sleep 0.5; echo "info: zoom needs to launch"
  sleep 0.5; echo "info: launching zoom now"
  if [[ -d "/Applications/zoom.us.app" ]]; then
    open "/Applications/zoom.us.app" &
  sleep 0.5; echo "info: finished installation"
elif [[ "${zoom_running}" == "NO" ]]; then
  sleep 0.5; echo "info: zoom does not need to launch"
sleep 0.5; echo "info: exiting post install"
Forum|alt.badge.img+31
  • July 2, 2019
I would urge everyone to look at something like AutoPKG to build the packages for you and then something like JSS Importer to automate the integration into jamf. Running curl scripts on endpoints as root is really not a great practice
  • July 3, 2019
ok that is bizarre.
I made a copy of the script I had for firefox (based on the same one this script is based on). I manually made the edits to do the install only, and this works fine now.
I had tried to just take the script in the OP but that doesn't seem to work. must have had a character somewhere causing it to error out.
Now i need to do a modification to add the preferences.
  • July 9, 2019
ImAMacGuy
Forum|alt.badge.img+23
  • July 9, 2019
Unless I'm misunderstanding, the DOS and disable camera by default is part of the current versions? So we can just patch the app at this point?
@greatkemo Funny you post that, as I was reading it last night before heading to bed, so I could get this addressed today. Personally, I don't like the way it does things so I have been looking for an excuse/justification to force our users to stop using it. This may do the trick =)
  • July 9, 2019
@greatkemo @bsatterthwaite there is another thread addressing the zero day exploit: https://www.jamf.com/jamf-nation/discussions/32561/zoom-exploit#responseChild187189
donmontalvo
Forum|alt.badge.img+36
  • July 12, 2019
Zoom client 4.4.53932.0709 resolves the vulnerability.
Apple's X-protect update prompts the user to "Allow".
Combine these two, and this should be a nothing-burger.
  • July 12, 2019
@jwojda
The big problem is, that when you uninstalled it, it left the web server intact. So, it sorta made you even "less secure" when the app was removed. The current version, claims to fix this.
  • July 12, 2019
Hey Nation, can we confirm if Apple pushed an XProtect or a MRT update to fix this? not seeing the XProtect update @donmontalvo mentioned in my SUS
ty
donmontalvo
  • July 12, 2019
@Nix4Life Do you get 1.45?
defaults read /System/Library/CoreServices/MRT.app/Contents/version CFBundleShortVersionString
Attribution:
https://www.jamf.com/jamf-nation/discussions/32561/zoom-exploit#responseChild187322
  • July 12, 2019
@donmontalvo
Yes, also hope the earthquake did not affect anything for you
donmontalvo
  • July 12, 2019
Oh crap I relocated to FL in October...better update my profile. :)
  • August 27, 2019
It looks like Zoom updated their versioning, at least the newest version (it contains parentheses now, so that's fun). I updated my script to the following, which seems to be working... no promises though. As always, please test before deploying large-scale.
Also, note that this is for Penn State, so you'll have to update your SSO URL depending on your environment.
# NAME
# SYNOPSIS
# HISTORY
#       Version: 1.1
#       - Shannon Johnson, 27.8.2019
#       (Updated to allow for parentheses in the currently installed version)
# Set preferences
hdvideo="true"
ssodefault="true"
lang=""
        lang=$4
        lang="en-US"
        currentinstalledver=`/usr/bin/defaults read /Applications/zoom.us.app/Contents/Info CFBundleShortVersionString | sed -e 's/0 //g' -e 's/(//g' -e 's/)//g'`
                 <dict>
                        <key>nogoogle</key>
                        <string>1</string>
                        <string>1</string>
                        <true/>
                        <true/>
                        echo "
                        <true/>
                        <key>ZSSOHost</key>
                        <true/>
                        <true/>
                </dict>
                /usr/bin/curl -sLo /tmp/${pkgfile} ${url}
                /bin/sleep 10
                        exit 1
  • August 27, 2019
HI @omatsei - I tried running your updated script a few minutes ago and got some strange behavior. Zoom was not installed on the machine, I ran the script, and at the end, the current version of the zoom client was installed. However, the script returned exit code 1 for some reason. In the script log, the script reports that the update was unsuccessful, and zoom remains uninstalled. The app does work at the end though.
Here is the terminal output, as well as the contents of the zoominstallscript.log:
Any ideas?
ind-eprice:~ eprice$ sudo jamf policy -event zoom
Password:
Checking for policies triggered by "zoom" for user "eprice"...
Executing Policy 23 - Zoom
Running script Install Zoom...
Script exit code: 1
Script result: Latest Version is: 4.5.3261.0825
Latest version of the URL is: https://zoom.us/client/4.5.3261.0825/ZoomInstallerIT.pkg
installer: Package name is Zoom
installer: Upgrading at base path /
installer: The upgrade was successful.
Error running script: return code was 1.
Submitting log to https://efe.jamfcloud.com/
Tue Aug 27 13:05:45 PDT 2019: Download URL: https://zoom.us/client/4.5.3261.0825/ZoomInstallerIT.pkg
Tue Aug 27 13:05:45 PDT 2019: Current Zoom version: none
Tue Aug 27 13:05:45 PDT 2019: Available Zoom version: 4.5.3261.0825
Tue Aug 27 13:05:45 PDT 2019: Downloading newer version.
Tue Aug 27 13:05:48 PDT 2019: Installing PKG...
Tue Aug 27 13:07:18 PDT 2019: Deleting downloaded PKG.
Tue Aug 27 13:07:18 PDT 2019: ERROR: Zoom update unsuccessful, version remains at none.
  • August 28, 2019
@eprice Same here! It seemed to work fine a week or two ago but I'm now getting the same error email. Not the end of the world since it seems like the install happens, but strange nonetheless.
