PPPC woes on Catalina (fr.whitebox.Packages)
  • February 11, 2020
  • 50 views
Ever since Catalina, I am unable to build packages with this app if using certain directories.. /var/tmp, /Library/LaunchDaemons, etc.
Is there something I am missing in the PPPC Profile? Composer works just fine without complaints.. Maybe cp needs access to all folders, or terminal?
I am an admin user and can create files in /Library/LaunchDaemons without needing authentication, so I am genuinely lost.
Best answer by seraphina
If anyone else experiences this..
You have to grant full disk access to /Library/PrivilegedHelperTools/fr.whitebox.packages/packages_dispatcher and /Library/PrivilegedHelperTools/fr.whitebox.packages/packages_builder
Annoying right??
  • February 11, 2020
Annoying right??
donmontalvo
Forum|alt.badge.img+36
  • June 18, 2020
Interesting, I use Whitebox Packages all the time.
I see Packages.app and packages_dispatcher in the Full Disk Access list, but I don't see packages_builder.
Posted a link to this thread on Stéphane Sudre's GitHub repo, though not sure if he is monitoring it, especially as 1.2.9 has been out a while and his repo only shows 1.2.8...I'll send him an email too.
Guessing it would be a good idea to add a page to his site, regarding whitelisting Packages.
donmontalvo
  • June 20, 2020
From: Packages Developer xxxx@xxxx.com Date: June 18, 2020 at 14:26:00 EDT To: Don Montalvo xxxx@xxxx.com Subject: Re: POPC question (URL)  Hello, Hope you are doing well. This might be the page you're looking for: http://s.sudre.free.fr/Software/Packages/Q&A_7.html
