Anybody have any successful experience NetBooting a client using a JSS Self Service policy?
We have a policy in the JSS called "Boot to NetBoot Server" which has "Restart Options" configured.
Configuration options set to the following:
Startup Disk: NetBoot
Boot Computers To: Specific NetBoot server
NetBoot Server: <netboot-server>
Both restart options are "Restart immediately"
I see the policy in Self Service and, after executing it, the computer reboots as expected, blinks the netboot globe splash screen for about a minute, and then boots to the current startup disk (as if booting up normally to the login screen). If I log into the local OS, I see in "Startup Items" that the NetBoot image is chosen to boot up to, but still does not NetBoot after clicking "Restart" in that window. The client is on the same subnet as the NetBoot server while the policy is executed and the NetBoot is attempted.
Disclaimer: This same NetBoot image typically boots normally and we have not seen any problems NetBooting before this (holding option or choosing the Startup Disk in System Preferences)
Client: Macbook Air
Client OS: OS X 10.8.4
JSS: 9.30
NetBoot Image: 10.8.5 (built on an MacBook Air)
NetBoot Server: Xserve running 10.6.8
Server Admin version: 10.6.5
