How to update Chrome automatically
  • March 8, 2017
  • 132 replies
  • 963 views
I have just written a blog post on how to automatically update Google Chrome using Jamf if anyone is interested. You can find my blog post here:
https://lew.im/2017/03/auto-update-chrome/
I have seen a few different methods posted here, but most require some admin intervention (uploading new packages, changing version numbers etc.) but this method is fully automated. Create the Extension Attribute, Smart Group and Policy and you're good to go! Every time Google release a new version of Chrome, this script will automatically grab it and install it on your Macs.
bpavlov
  • March 8, 2017
I haven't implemented this, but just reading through the script, it looks like you are literally overwriting the Google Chrome.app on the client already. In my experience having done this with a package in the past, this has the effect of causing issues when new tabs are opened and not being able to navigate to new websites. So in essence if you want to do this, you need to make sure Google Chrome is not opened otherwise the user may run into that issue. Again, I haven't tested your workflow so I'm going off what I'm reading in that script. Curious to hear how long you've been using this workflow and what your experience has been from the end-user side.
  • March 8, 2017
We have been using this method (less the automated version part) for around a year now, and haven't had any issues. With a few hundred Macs reporting in, I'd probably have heard a complaint or two if it was causing issues with new tabs!
I tested it when we initially deployed it and all seemed fine, but Chrome has changed a lot since then, so I'll do some further testing when I'm back in the office and will update you.
  • March 9, 2017
@bpavlov just did some further testing, ran the script a few times deleting Chrome whilst using it, open new tabs, browsing etc. and didn't notice anything whatsoever.
So can confirm there is still no noticeable effect for the end user if you run this.
  • March 9, 2017
Saw your post on Reddit about this script. Going to install it today and give it a run.
Thanks for sharing.
  • March 9, 2017
@LewisLebentz Thanks for your post, and showing your work. If nothing else, you pointed me to a resource I was previously unaware of. I'm not sure who developed or maintains the omahaproxy pages, but I looked it up to see more on it. It doesn't appear to be something Google maintains, but I'm not completely sure on that.
In any event, I've been looking for a more reliable way to get the Google Chrome current release number, since it seems Google obscurs it to the point of being impossible to get. I also have an "update" script that can update several products on the fly, doing live version checking, and incorporating Google Chrome into it has been a bear, because it was such a moving target to locate the latest version.
I found the team at omahaproxy have a simple plain csv file they host as well and was able to come up with the following very simple bash code to pull the current Mac version release from that. Posting it here so others can benefit.
curl -s https://omahaproxy.appspot.com/history | awk -F',' '/mac,stable/{print $3; exit}'
The above prints
56.0.2924.87
which is the current version. I'll need to see if that still works when they release an update.
Hopefully those pages won't up and disappear someday, or go stale from lack of maintenance.
  • March 9, 2017
LOL! No sooner did I post the above and Google released an update. Didn't need to wait long! The code above (and I assume your python EA as well) is working to show the new version, 57.0.2987.98, which means those pages get updated simultaneously along with new releases. Wow! Impressive!
  • March 10, 2017
@mm2270 just noticed the update too! Most of my Macs have already picked up the update because of the script, which is great!
I believe the OmahaProxy site is officially Google, I've seen it referred to in a few different places by Google. So I think it's safe to rely on, it's been around for a while too.
Just found some code that references it on Google's site: https://chromium.googlesource.com/chromium/chromium/+/trunk/tools/omahaproxy.py
Script is pretty similar to mine!
Thanks for sharing your code too. Much shorter than mine! Need to learn how to use awk at some point.
I did notice that Jamf haven't yet updated their patch reporting, so our pie chart is all red saying that the version number is 'Other' and in the list it reports it as 'Unknown' which isn't great.
Forum|alt.badge.img+15
  • March 10, 2017
Why use this work flow over Google's own system wide automatic updater? Especially when it can be enabled with a script.
  • March 10, 2017
@cbrewer ours users are all admins, so can override settings we push out. Even if they don't they may not restart Chrome.
This script forces an update on check in, without the user even noticing. It runs in the background, and doesn't require a restart of Chrome.
  • March 13, 2017
So with @mm2270 new script, what should final Extension Attribute code look like? Sorry i'm new to this and pretty green when it comes to coding.
bpavlov
  • March 15, 2017
@cbrewer what's the script you're referring to use the internal update tool from Google?
  • March 15, 2017
  • April 25, 2017
Hey @LewisLebentz
Excellent post!
  • August 16, 2017
Thanks ! @LewisLebentz @mm2270
What a time saver! i've seen no issues using it whilst Chrome is open,
it will also install the latest Chrome if it's not installed, here's the EA i'm using to report,
if [ ! -f "/Applications/Google Chrome.app/Contents/Info.plist" ] ; then
echo "<result>Chrome isn't installed</result>"
INSTALLEDVERSION=$( defaults read "/Applications/Google Chrome.app/Contents/Info.plist" CFBundleShortVersionString )
CURRENTVERSION=$( curl -s https://omahaproxy.appspot.com/history | awk -F',' '/mac,stable/{print $3; exit}' )
if [[ "$INSTALLEDVERSION" == "$CURRENTVERSION" ]]; then
echo "<result>latest - $CURRENTVERSION</result>"
echo "<result>old</result>"
  • August 17, 2017
@mm2270 @LewisLebentz pardon my ignorance but I would love to get this working at my site. I saw the curl command that @mm2270 put above and i saw it incorporated into the EA that @May wrote. What I don't understand is how that curl command pulls down the latest version and installs it. What am I missing.
Thanks,
  • August 17, 2017
@Kyuubi The script above from @May is an Extension Attribute, not the script that updates Chrome. The EA is part of the whole workflow put together by @LewisLebentz in his original post up top. You would use an EA similar, or identical to the one May posted above to gather Macs that are out of date according to what is noted on the omahaproxy pages for the latest Chrome version. This can then be used to gather out of date Macs in a Smart Group, which can in turn be scoped to the policy that would update them. Refer to Lewis' OP at top for his script that updates Chrome. There are others posted on the forums here as well. Essentially any script that would pull Google Chrome down, mount the DMG, copy over the app (overwriting the old one) and so on and so forth.
Hope that helps.
  • August 18, 2017
@mm2270 Thanks for the response. I understand all you wrote above, I'm just having trouble finding the actual script that does the pulling and installing. I've checked @LewisLebentz blog and github pages but can't find the script. Making me feel stupid.
  • August 18, 2017
.......found it
  • August 18, 2017
@Kyuubi OK, good! Was just about to post a more direct link to the script if I could for you. :)
Forum|alt.badge.img+19
  • August 19, 2017
I actually incorporate the chrome_enable_autoupdates.py as a postinstall in my AutoPKG Chrome recipe now and this seems to be working well.
  • September 22, 2017
@LewisLebentz Not working for me, maybe missing a step or something. When Lewis says " I made a Smart Group targeting all Macs where Chrome Version = Old" how does that translate into the Smart Group, how do you create it.
Thanks
  • October 17, 2017
@LewisLebentz Any update on creating the Smart Group? This would be great to implement but I am in the position as @tld75000. How do you create a Smart Group with the Criteria of "Chrome = Old"? Any help would be appreciated. Thanks.
  • January 9, 2018
@JeffA you can do a smart group with the criteria "Chrome like old"
  • January 10, 2018
The windows pop up message when the new version of chrome launch. I don't think so you need to go for automatic chrome update.
  • September 12, 2018
@JeffA You've probably figured this out already. For anyone who creates the Extension Attribute, you would create a Smart Group and there will be a "New Criteria" with whatever you named the EA. For example, I named mine Chrome Version, so I have a new criteria option called Chrome Version, then I just use the value is "old".
