We upgraded to 9.97.1488392992. Once the install was complete, the web service quit working and we haven't been able to make it work. Log shows web service is closing all attempts to connect. Has anyone experienced this?
Web service not working after hot fix 9.97.1488392992
Best answer by chriscollins
@officeit if you used the Linux installer it's most likely because of an issue with the installer not moving your SSL keystore back into the appropriate spot. So basically the JSS is running but can't serve https connections. The fix is simple though.
Go into /use/local/jss/backups and navigate to the latest backup the installer made and go into the tomcat folder and copy the backup of your keystore file back into /usr/local/JSS/tomcat/ and restart tomcat. It should load up now.
