Deploy EAP-TLS WPA2E SSID with user certs
  • October 24, 2016
  • 5 replies
  • 60 views
Hi together,
firstly I would like to say that I am new to the community and hope to find some help here. Also a sorry if the form of creating questions may not be correct.
We would like to pre-publish a network SSID via plist or script of possible which does eap-tls auth with a user based certificate ( due to mac is not AD bound ) we can assume the certificate is already stored within the keychain.
I already created following bash script:
networksetup -addpreferredwirelessnetworkatindex en0 NETWORKNAME 1 WPA2E
security set-identity-preference -c "USER NAME" -s "NETWORKNAME"
this alread pre-populates the network ssid but user still has to select EAP-TLS and correct certifcate.
To make clear what I want to do i attach pictures to manually connect to the network:
Thanks for the help
  • October 25, 2016
Hi Chris, how did you get the user cert on a non ad machine using jamf ? should you not have active directory authentication issues ?
  • October 25, 2016
@Tigerhaven no, there are PKI solutions that can generate the certificates without joining the Mac to the domain via self-enrollment (like Symantec Managed PKI).
  • October 25, 2016
Yes @sislam is right, there are PKI solutions facing this. Anyone a idea how this could be handled?
  • October 25, 2016
@sislam and @chris83 for microsoft based certs any suggestions that work well with jamf ?
  • October 27, 2016
The local machine does not have any microsoft based certs to work with, that is one of the features of using PKI.
Basically this is just setting a identity for a configured ssid based on a certificate in the keychain. Maybe I am on the wrong track but according to this page: https://discussions.apple.com/thread/4922201?tstart=0 it should help.
