JSS Error - AWS - Unable to Create Distribution
  • March 10, 2019
  • 26 views
I keep getting the following error in JAMF - unable to create distribution for this bucket - when trying to setup a cloud distribution point using AWS S3. This is a new install of version 10.10.1 and MySQL 8.0 using Java 8 update 202 I've done the following:
-Installed SSL cert on JSS
-Created a user in AWS with permissions stated in this kb - I even added additional permission for Cloudfront in an attempt to troubleshoot - https://www.jamf.com/jamf-nation/articles/643/integrating-amazon-web-services-aws-with-jamf-pro
-When I look in S3 after the error, a bucket was actually created. When I look in Cloudfront, distribution was actually created. However I get this error message and cannot save the distribution point.
Any ideas?
  • April 1, 2020
Having the same issue. Were you able to figure this out? Bucket is created but "Unable to Create Distribution" error.
  • April 15, 2020
Quick update, it was a permission issue with AWS. You can TEMPORARILY verify that it is the permission by changing
"cloudfront:CreateCloudFrontOriginAccessIdentity"
and
"s3:AbortMultipartUpload",
"cloudfront: *"
AND
"s3:*"
After doing this, change the settings back.
  • April 17, 2020
Sorry, I haven't checked in in several days. You are correct. It was a permission issue for me as well. I ended up following this guide: https://derflounder.wordpress.com/2017/03/07/creating-a-jamf-pro-cloud-distribution-point-using-amazon-web-services/
