Mobile Self Service App prompting "Registration Not Complete"
  • June 29, 2016
  • 4 replies
  • 32 views
When we open our Self Service App for iOS, we are getting the "Registration Not Complete" message now.
"Register with the following accounts to receive apps and eBooks."
We only use Device Assigned VPP so not sure why this message is appearing. Do anyone have any suggestions on how to suppress this message? It appears every time they open the Self Service app.
Best answer by chzar
Check to make sure you are not assigning apps using both user and device based assignments. It causes a conflict and consequently that error message. Fixed the problem for me.
bentoms
Forum|alt.badge.img+35
  • June 30, 2016
@tak10 Might be related to the issue mentioned here.
  • August 11, 2016
I am also having the exact same problem and have been unable to find a solution thus far.
  • August 11, 2016
  • October 6, 2016
I had one Mac OS X app that was using User assigned VPP. This was assigned prior to Apple coming out with device based VPP. No more annoying prompt.
