Login attempt history?
  • January 3, 2018
  • 4 replies
  • 142 views
Hello, does macOS 10.13 keep an authentication log anywhere? I don't see the accountpolicy.log in /var/log anymore... so Im assuming Apple moved it into log facility?
I need to audit a Mac for login success/fail attempts at the screensaver/login window. Any help would be appreciated!
davidacland
  • January 3, 2018
you might be able to get the information from the log command-line tool. Something like this:
log show --last 300 --predicate 'eventMessage contains "Failed to authenticate user"' | grep "Failed to authenticate user"
  • April 30, 2018
So I've got the same issue. I have a sort of similar solution. I use the log tool to grep for a specific line that specifies when a user attempts to login on a machine that is locked out. Unfortunately today we got a false positive so apparently this event is generated by more than just authentication attempts against a locked machine. FWIW here is the command I'm running:
log show --style syslog --last 60s | grep -i 'FailedsAuthenticationsPolicy'
This searches through the logs over the last 60 seconds for the regex in the single quotes. You can do any regex you like with grep. I think there's a way to use the above using 'eventMessage' but I couldn't get that to work so I use grep. I know it's not the same thing you are looking for but it's similar and might give you some ideas.
dan-snelson
Forum|alt.badge.img+30
  • June 28, 2018
@Sonic84 We're using the following as an Extension Attribute for failed logins within the last 24 hours:
# Extension Attribute to determine the number of failed login attempts during a specified duration
# See: log help show
searchDuration="24h"  # [--last <num>[m|h|d] ]
failedLoginAttempts=$( /usr/bin/log show --last "${searchDuration}" --style syslog --predicate 'eventMessage contains "Failed to authenticate user"' | /usr/bin/wc -l | /usr/bin/tr -d ' ' )
echo "<result>$failedLoginAttempts</result>"
dlondon
  • April 3, 2024
When I just use a general form of the log  show command I get output like this:
log show --predicate '(eventMessage CONTAINS "Authentication failed")' --style syslog
Filtering the log data using "composedMessage CONTAINS "Authentication failed""
Skipping info and debug messages, pass --info and/or --debug to include.
Timestamp (process)[PID]
2024-04-02 08:39:10.906297+0800 localhost opendirectoryd[170]: (PlistFile) [com.apple.opendirectoryd:auth] Authentication failed for <private> (907B8838-1A52-4DD3-A0DD-EF183620FED5): ODErrorCredentialsInvalid
2024-04-02 10:35:28.279550+0800 localhost opendirectoryd[170]: (PlistFile) [com.apple.opendirectoryd:auth] Authentication failed for <private> (CA986D08-8CB4-43C5-ABAB-18644A29C97C): ODErrorCredentialsInvalid
Is there a way to unhide <private> ?
