Slides available
  • November 6, 2014
  • 21 views
Hi Everyone,
A PDF of the slides from my JNUC 2014 presentation (Objects to Objects, The Casper Suite API through Ruby) are now available at http://pixaranimationstudios.github.io/jss-api-gem/Object_To_Objects-JSS_API_Through_Ruby.pdf
The home page for the open-source jss-api Ruby Gem is at http://pixaranimationstudios.github.io/jss-api-gem/
Cheers!
-Chris
  • November 8, 2014
Thank you!
roiegat
  • November 10, 2014
Thank you.....when will Puppytime be available? Thanks for all the great info in your session.
  • November 11, 2014
You're welcome!
I'm aiming to release 'd3' (which includes puppytime) in the first quarter of next year - I'm still re-writing it to use the open-sourced version of the jss-api gem. That said, I can't make predictions about how long the approval process will take. When things start to become clearer, I'll be posting to JAMFNation!
Cheers,
-Chris
