Applescript times out around 5 minutes
  • June 30, 2016
  • 6 replies
  • 30 views
Goal: I want to have a script that will restart a system, if no user is logged in, or prompt a logged in user that their computer is going to be restarted in 30 minutes, and give them an option to postpone that restart.
I found the following script ( https://jamfnation.jamfsoftware.com/viewProductFile.html?fid=477 ), and it appears to work, except it always restarts after running for just 5 minutes.
If I copy the large chunk of AppleScript code into Script Editor, and run it there, it works fine for the full duration (30 minutes).
I have tried adding some pieces like "with timeout of 1800 seconds", but i get the same result. I have also tried on multiple OS's (10.11-10.9).
Could anyone clue me in on why the Applescript is acting differently when run from inside a .sh script?
Best answer by jmcconathy
I tried the 'with timeout' option also, but it still would not work as expected. So I have just dumped this and written my own python script using cocoa dialog that does what I want.
Thanks for the suggestions though.
  • June 30, 2016
Are you runnning it as a policy? You haven't set a restart condition on the policy itself? That defaults to 5 minutes I believe...
  • June 30, 2016
Negative, I have tried running this script from terminal to rule out anything like that.
  • July 1, 2016
Do a "with timeout of #### seconds" after the activate line. Here is an example from one of my scripts where I set the time-out slightly longer than the longest I possibly want the script to run. Then the timeouts within will have time to work.
    tell application "Finder"
    activate
    with timeout of 86400 seconds
Forum|alt.badge.img+15
  • July 1, 2016
Because it's a Friday before a long weekend and I'm trying to avoid my own work, I created this template. Hopefully it helps you- or at least parts of it.
Run the script below frequently on your machines. It looks for a key in /tmp/rebootTrack. If that key exists, the user is prompted to restart, and it does reboot automatically with a 30 minute (1801 second) countdown if someone is logged in. They can delay the reboot 5 times. Run the script again to prompt the user again. Either with LaunchD or Policy.
#Thoule
JH="/Library/Application Support/JAMF/bin/jamfHelper.app/Contents/MacOS/jamfHelper"
JHaddon=" -windowType utility -title IT_Message -icon /usr/local/Logos/Square_Black.png "
needReboot=$(defaults read /tmp/rebootTrack rebootNeeded)
if [ "$needReboot" != "YES" ]; then
    echo "no reboot required at this time"
    exit 1
currentUser=$(stat -f '%Su' /dev/console)
snoozeCount=$(defaults read /tmp/rebootTrack snoozeLeft)
if [ -z $snoozeCount ]; then  #if no value returned
    snoozeCount=5 #get five snoozes by default.
    defaults write /tmp/rebootTrack snoozeLeft -int 5
alreadyRunning=$(defaults read /tmp/rebootTrack runningNow)
if [ -z $alreadyRunning ]; then
    defaults write /tmp/rebootTrack runningNow -string "running"
    echo "another instance of this script is running.  I'll quit now."
    exit 1
if [ "$currentUser" == "root" ]; then
    echo "rebooting here"
    /sbin/reboot
    "$JH" $JHaddon -description "Reboot Pending.  Get yerself ready!  You have $snoozeCount delays left" -timeout 1801 -button2 "Delay" -button1 "Reboot" -countdown
    response=$?
    if [ "$response" == "0" ] || [ $snoozeCount < 1 ]; then    #if reboot clicked
        echo "rebooting Here!"
        /sbin/reboot
        snoozeCount=$((snoozeCount-1))
        defaults write /tmp/rebootTrack snoozeLeft $snoozeCount
#cleanup
defaults delete /tmp/rebootTrack runningNow
  • July 12, 2016
bentoms
Forum|alt.badge.img+35
  • July 13, 2016
Just chiming in, never had luck with the timeout flag for anything more than 5 minutes.
CocoaDialog or (if an app), building a XIB works. (Had to do this in AutoCasperNBI).
