Imaging, stalls on 'delete adobeinstall'
  • January 29, 2013
  • 7 views
dpertschi
Forum|alt.badge.img+19
I'm configuring a new instance of Casper at another office location, similar to the one I'm already running at HQ.
Problem I've got is that the machine being imaged never finishes up behind the jamfHelper full screen lock. Looking at the clients jamf.log, the last entry is 'Deleting home directory for adobe install...'
Subsequent reboots sends it right back to the full screen block also.
EDIT: and then after letting it sit like that for a few hours the jamf.log did move on to 'Checking for policies...'. So why so damn slow....
Casper 8.6, 10.7.5 image
Best answer by dpertschi
Solved: it was a corrupt package
1 reply
dpertschi
  • January 30, 2013
