Smart Group based on Plug-ins
  • October 14, 2009
  • 35 views
I want to create a Smart Group based on Plug-Ins but It's not working for
me. Is the Plugin Title looking for things located in /Library/Internet
Plug-Ins? If so, what do I use as the Title - just the name of the plugin
file?
For example, if I create a test group and use "Flip4Mac WMV Plugin" as the
title name it finds 0 computers. However, we should have several thousand
computers with that plug-in installed.
Forum|alt.badge.img+15
  • October 14, 2009
Chad-
Flip for mac is also an application.
you would search for application title called WMV Player.app
you need the file extension at the end or it doesn't like it.
see attached
Thanks
Dan
![external image link](attachments/3dfd8f86b7324f8aaedcd78298c3dd21)
  • October 14, 2009
I was just using Flip4Mac as an example. I need the Plugin Title to work. We've got a 3rd party web app that requires a plug-in and there's no
associated application.
![external image link](attachments/d46e58d010764bcab33daf4b4549bfba)
  • October 14, 2009
Chad-
go to your web interface
Settings- Inventory options - inventory Preferences and click the software tab
click the Add custom search path hyperlink
add the plugin path /Library/Internet Plug-Ins
make your smart group based on
plugin Title has Flash Player.plugin
You should be good to go.
Flash player was just an example ;0)
Dan
