Custom Schemas For Application Configuration Profiles
  • February 14, 2020
  • 63 replies
  • 624 views
noahdowd
I created a couple of custom schemas in JSON for this new feature. Just cause I'm excited about it! I learned JSON schemas today to do this, so they might be a little basic but maybe someone will find them useful.
Enterprise Connect:
    "$schema": "http://json-schema.org/schema#",
    "definitions": {
        "share": {
            "type": "object",
            "properties": {
                "path": {"type": "string"}
    "type": "object",
    "properties": {
        "adRealm": {"type": "string", "default": ""},
        "alwaysGetNewTicket": {"type": "boolean", "default": "false"},
        "checkForNetworkServer": {"type": "string", "default": ""},
        "checkForNetworkType": {"type": "boolean", "default": "false"},
        "checkShowLegacyCertificates": {"type": "boolean", "default": "false"},
        "connectDelay": {"type": "integer", "default": 0, "minimum": 0},
        "connectionCompletedScriptPath": {"type": "string", "default": ""},
        "connectReminderNagInterval": {"type": "integer", "default": 86400, "minimum": 0},
        "connectReminderTime": {"type": "integer", "minimum": 0},
        "dailyReconnectTime": {"type": "integer", "default": 86400, "minimum": 0},
        "debugMode": {"type": "boolean", "default": "false"},
        "destroyKerbTicketUponCardRemoval": {"type": "boolean", "default": "true"},
        "disablePasswordExpirationChecking": {"type": "boolean"},
        "disablePasswordFunctions": {"type": "boolean", "default": "false"},
        "managedshares": {
            "type": "array",
            "items": {"$ref": "#/definitions/share"},
            "default": []
        "mountNetworkHomeDirectory": {"type": "boolean", "default": "false"},
        "orgLogoPath": {"type": "string"},
        "orgUsernameLabel": {"type": "string"},
        "passwordChangeScriptPath": {"type": "string"},
        "passwordChangeURL": {"type": "string"},
        "passwordExpireOverride": {"type": "integer", "minimum": 0},
        "passwordNotificationDays": {"type": "integer", "default": 15, "minimum": 0},
        "preferredDC": {"type": "string"},
        "prepopulatedUsername": {"type": "string", "default": ""},
        "pwReqComplexity": {"type": "boolean", "default": "false"},
        "pwReqComplexityDisableUnicode": {"type": "boolean", "default": "false"},
        "pwReqHistoryCount": {"type": "integer", "minimum": 0},
        "pwReqLength": {"type": "integer", "minimum": 0},
        "pwReqMinimumPasswordAge": {"type": "integer", "minimum": 0},
        "pwReqText": {"type": "string", "default": ""},
        "runAuditScript": {"type": "boolean"},
        "runAuditScriptPath": {"type": "string"},
        "runPasswordChangeScriptOnLocalPasswordSync": {"type": "boolean", "default": "true"},
        "runPeriodicStateCheck": {"type": "boolean", "default": "true"},
        "setupReminderNagInterval": {"type": "integer", "default": 86400, "minimum": 0},
        "shareMountWaitSeconds": {"type": "integer", "default": 0, "minimum": 0},
        "showKeychainIdentities": {"type": "boolean", "default": "false"},
        "showMenuExtra": {"type": "boolean", "default": "true"},
        "showUsernameWithSmartcard": {"type": "boolean", "default": "false"},
        "smartCardMode": {"type": "boolean", "default": "false"},
        "syncLocalPassword": {"type": "boolean"}
And Firefox:
    "definitions": {
        "bookmark": {
            "type": "object",
            "properties": {
                "Folder": {"type": "string"},
                "URL": {"type": "string"},
                "Title": {"type": "string"},
                "Favicon": {"type": "string"},
                "Placement": {"type": "string"}
    "type": "object",
    "properties": {
        "DisableSetDesktopBackground": {"type": "boolean", "default": "true"},
        "Preferences": {
            "type": "object",
            "properties": {
                "app.update.auto": {"type": "boolean", "default": "true"},
                "security.default_personal_cert": {"type": "string", "default": "Ask Every Time"}
        "DisableProfileImport": {"type": "boolean", "default": "true"},
        "DisableSecurityBypass": {
            "type": "object",
            "properties": {
               "InvalidCertificate": {"type": "boolean", "default": "true"},
               "SafeBrowsing": {"type": "boolean", "default": "true"}
        "DNSOverHTTPS":{
            "type": "object",
            "properties": {
               "Enabled": {"type": "boolean", "default": "false"},
               "Locked": { "type": "boolean", "default": "true"},
               "ProviderURL": { "type": "string", "default": "URL_TO_ALTERNATE_PROVIDER" }
        "CaptivePortal": { "type": "boolean", "default": "false" },
        "DisableAppUpdate": { "type": "boolean", "default": "true" },
        "DefaultDownloadDirectory": { "type": "string", "default": "${home}/Downloads" },
        "DontCheckDefaultBrowser": { "type": "boolean", "default": "true" },
        "SSLVersionMin": { "type": "string", "default": "tls1.2" },
        "Certificates":{
            "type": "object",
            "properties": {
               "Install": {
                "type": "array",
                "items": {"type": "string"},
                "default": ["cert1.der","cert2.pem"]
               "ImportEnterpriseRoots": { "type": "boolean", "default": "true" }
        "Homepage":{
            "type": "object",
            "properties": {
               "URL": { "type": "string", "default": "http://example.com" },
               "Additional": {
                "type": "array",
                    "default": ["https://www.example.com/extra-home1.htm","https://www.example.com/extra-home2.htm","https://www.example.com/extra-home3.htm"]
               "Locked": { "type": "boolean", "default": "true" },
                "StartPage": { "type": "string", "default": "homepage"}
        "DisableFormHistory": { "type": "boolean", "default": "true" },
        "SupportMenu":{
            "type": "object",
            "properties": {
               "Title": { "type": "string", "default": "Click here for help" },
               "URL": { "type": "string", "default": "http://example.edu/" },
               "AccessKey": { "type": "string", "default": "C" }
        "DisableSafeMode": { "type": "boolean", "default": "true" },
        "ExtensionUpdate": { "type": "boolean", "default": "false" },
        "DisableSystemAddonUpdate": { "type": "boolean", "default": "true" },
        "DisableFirefoxScreenshots": { "type": "boolean", "default": "true"},
        "FlashPlugin":{
            "type": "object",
            "properties": {
                "Allow": {
                    "type": "array",
                    "default": ["https://www.example.com"]
               "Block": {
                    "type": "array",
                    "default": ["https://www.example.org"]
               "Default": { "type": "boolean", "default": "true" },
        "DisableFirefoxAccounts": { "type": "boolean", "default": "true" },
        "ExtensionSettings":{
            "type": "object",
            "properties": {
                "type": "object",
                "properties": {
                      "blocked_install_message": {"type": "string", "default": "Custom error message"},
                      "install_sources": {
                            "type": "array",
                            "default": ["https://addons.mozilla.org/"]
                      "installation_mode": {"type": "string", "default": "blocked"}
               "uBlock0@raymondhill.net":{
                "type": "object",
                "properties": {
                      "installation_mode": {"type": "string", "default": "force_installed"},
                      "install_url": {"type": "string", "default": "https://addons.mozilla.org/firefox/downloads/latest/ublock-origin/latest.xpi"}
        "DisplayBookmarksToolbar": { "type": "boolean", "default": "true" },
        "HardwareAcceleration": { "type": "boolean", "default": "false" },
        "DisablePrivateBrowsing": { "type": "boolean", "default": "true" },
        "EnterprisePoliciesEnabled": { "type": "boolean", "default": "false" },
        "Bookmarks": {
            "type": "array",
            "items": {"$ref": "#/definitions/bookmark"},
            "default": [{"Folder":"Example1Folder","URL":"https://www.example.org","Title":"Example1","Favicon":"https://www.example.org/favicon.ico","Placement":"toolbar"},{"Folder":"Example2Folder","URL":"https://www.example.com","Title":"Example2","Favicon":"https://www.example.com/favicon.ico","Placement":"menu"}]
        "NetworkPrediction": { "type": "boolean", "default": "false" },
        "EnableTrackingProtection":{
            "type": "object",
            "properties": {
               "Fingerprinting": { "type": "boolean", "default": "true" },
               "Value": { "type": "boolean", "default": "true" },
               "Cryptomining": { "type": "boolean", "default": "true" }
        "OverrideFirstRunPage": {"type": "string", "default": "https://www.example.com"},
        "Extensions":{
            "type": "object",
            "properties": {
               "Install": {
                "type": "array",
                "default": ["https://addons.mozilla.org/firefox/downloads/file/1053714/ghostery_privacy_ad_blocker-8.2.4-an+fx.xpi"]
               "Uninstall": {
                "type": "array",
                "default": []
               "Locked":
                "type": "array",
                "default": ["firefox@ghostery.com"]
        "Authentication":{
            "type": "object",
            "properties": {
               "NTLM": {
                "type": "array",
                "default": ["mydomain.com","https://myotherdomain.com"]
               "Delegated": {
                "type": "array",
               "AllowNonFQDN":{
                "type": "object",
                "properties": {
                    "SPNEGO": { "type": "boolean", "default": "true" },
                    "NTLM": { "type": "boolean", "default": "true" }
               "AllowProxies":{
                "type": "object",
                "properties": {
               "SPNEGO": {
                "type": "array",
        "Proxy":{
            "type": "object",
            "properties": {
               "SocksVersion": {"type": "string", "default": "4"},
               "Mode": {"type": "string", "default": "manual"},
               "HTTPProxy": {"type": "string", "default": "proxy.example.com:80"},
        "SecurityDevices":{
            "type": "object",
            "properties": {
               "NAME_OF_DEVICE": {"type": "string", "default": "PATH_TO_LIBRARY_FOR_DEVICE"}
        "OverridePostUpdatePage": {"type": "string", "default": ""},
        "BlockAboutSupport": { "type": "boolean", "default": "true" },
        "LocalFileLinks": {
            "type": "array",
            "default": ["http://example.org","http://example.edu"]
        "Permissions":{
            "type": "object",
            "properties": {
               "Camera":{
                "type": "object",
                "properties": {
                      "Allow": {
                        "type": "array",
                        "default": ["https://example.org"]
                      "BlockNewRequests": { "type": "boolean", "default": "true" },
                      "Block": {
                        "type": "array",
                        "default": ["https://example.edu"]
               "Microphone":{
                "type": "object",
                "properties": {
                      "Allow": {
                        "type": "array",
                      "Block": {
                      "type": "array",
               "Location":{
                "type": "object",
                "properties": {
                      "Allow": {
                        "type": "array",
                      "Block": {
                      "type": "array",
               "Notifications":{
                "type": "object",
                "properties": {
                      "Allow": {
                        "type": "array",
                      "Block": {
                      "type": "array",
        "PasswordManagerEnabled": { "type": "boolean", "default": "false" },
        "NoDefaultBookmarks": { "type": "boolean", "default": "true" },
        "FirefoxHome":{
            "type": "object",
            "properties": {
               "TopSites": { "type": "boolean", "default": "true" },
               "Pocket": { "type": "boolean", "default": "false" },
               "Search": { "type": "boolean", "default": "true" },
               "Snippets": { "type": "boolean", "default": "false" },
               "Highlights": { "type": "boolean", "default": "true" }
        "DisableFeedbackCommands": { "type": "boolean", "default": "true" },
        "DisablePasswordReveal": { "type": "boolean", "default": "true" },
        "AppUpdateURL": {"type": "string", "default": "https://www.example.com/update.xml"},
        "DisableTelemetry": { "type": "boolean", "default": "true" },
        "DisableDeveloperTools": { "type": "boolean", "default": "true" },
        "SearchBar": {"type": "string", "default": "separate"},
        "WebsiteFilter":{
            "type": "object",
            "properties": {
               "Block": {
                "type": "array",
                "default": ["<all_urls>"]
               "Exceptions": {
                    "type": "array",
                    "default": ["https://www.google.com/*","https://www.yahoo.com/*"]
        "DisableFirefoxStudies": { "type": "boolean", "default": "true" },
        "DownloadDirectory": {"type": "string", "default": "${home}/Downloads"},
        "BlockAboutConfig": { "type": "boolean", "default": "true" },
        "DisableMasterPasswordCreation": { "type": "boolean", "default": "true" },
        "SanitizeOnShutdown": { "type": "boolean", "default": "true" },
        "InstallAddonsPermission":{
            "type": "object",
            "properties": {
               "Allow": {
                "type": "array",
                "default": ["https://example.org","https://example.edu"]
               "Default": { "type": "boolean", "default": "false" }
        "DisablePocket": { "type": "boolean", "default": "true" },
        "DisableBuiltinPDFViewer": { "type": "boolean", "default": "true" },
        "DisableProfileRefresh": { "type": "boolean", "default": "true" },
        "NewTabPage": { "type": "boolean", "default": "false" },
        "OfferToSaveLoginsDefault": { "type": "boolean", "default": "false" },
        "OfferToSaveLogins": { "type": "boolean", "default": "false" },
        "SSLVersionMax": {"type": "string", "default": "tls1.3"},
        "BlockAboutAddons": { "type": "boolean", "default": "true" },
        "RequestedLocales": {
            "type": "array",
            "default": ["de","en-US"]
        "BlockAboutProfiles": { "type": "boolean", "default": "true" },
        "Cookies":{
            "type": "object",
            "properties": {
               "ExpireAtSessionEnd": { "type": "boolean", "default": "true" },
               "Default": { "type": "boolean", "default": "false" },
               "Allow": {
                "type": "array",
                "default": ["https://www.example.org/"]
               "RejectTracker": { "type": "boolean", "default": "true" },
               "Block": {
                "type": "array",
                "default": ["https://www.example.edu/"]
               "AcceptThirdParty": {"type": "string", "default": "never"}
        "DisableForgetButton": { "type": "boolean", "default": "true" },
        "PopupBlocking":{
            "type": "object",
            "properties": {
               "Allow": {
                "type": "array",
                "default": ["https://www.example.org","https://www.example.edu"]
talkingmoose
Forum|alt.badge.img+36
  • Community Manager
  • February 15, 2020
I absolutely love this!
You're doing exactly as I'd hoped when I first learned of this feature internally, which is the community would help build manifests and share them with others. You've also given some very interesting examples of what these manifests can do too.
We're planning to provide a lot more next week to help the Jamf community discover and use management manifests. Stay tuned.
And thanks for sharing!
noahdowd
  • February 18, 2020
Hey no problem! Here's one for Safari. I'm definitely getting better at this. Still some room for improvement of course.
    "type": "object",
    "properties": {
        "HomePage": {
            "type": "string",
            "title": "Homepage",
            "description": "Homepage URL",
            "default": ""
        "NewWindowBehavior": {
            "type": "number",
            "title": "Contents of new windows",
            "description": "1 = Homepage, 2 = Empty Page, 3 = Same Page As Current Window, 4 = Bookmarks",
            "default": 0,
            "enum": [0, 1, 2, 3, 4]
        "NewTabBehavior": {
            "type": "number",
            "title": "Contents of new tabs",
            "default": 0,
        "TabCreationPolicy": {
            "type": "number",
            "title": "Open pages in tabs instead of windows",
            "description": "0 = Never, 1 = Automatically, 2 = Always",
            "enum": [0, 1, 2]
        "CommandClickMakesTabs": {
            "type": "boolean",
            "title": "Command-click opens a link in a new tab",
            "default": "true"
        "OpenNewTabsInFront": {
            "type": "boolean",
            "title": "When a new tab or window opens, make it active",
            "default": "false"
        "HistoryAgeInDaysLimit": {
            "type": "number",
            "title": "Remove history items",
            "description": "Number of days to retain history",
            "enum": [1, 7, 14, 30, 365, 365000]
        "DownloadsPath": {
            "type": "string",
            "title": "Downloads location",
            "description": "File system path (can start with ~) where downloaded files will be saved.",
            "default": "~/Downloads"
        "DownloadsClearingPolicy": {
            "type": "number",
            "title": "Remove download list items",
            "description": "0 = Manually, 1 = When Safari quits, 2 = Upon successful download",
            "enum": [0, 1, 2]
        "AutoOpenSafeDownloads": {
            "type": "boolean",
            "title": "Open "safe" files after downloading",
            "description": ""Safe" files include movies, pictures, sounds, PDF and text documents, and archives.",
            "default": "true"
        "ConfirmClosingMultiplePages": {
            "type": "boolean",
            "title": "Confirm closing multiple pages",
            "default": "true"
        "DefaultBrowserPromptingState2": {
            "type": "number",
            "title": "Suppress default web browser prompt",
            "enum": [1]
        "BookmarksMenuIncludesBookmarksToolbar": {
            "type": "boolean",
            "title": "Bookmarks Menu includes Bookmarks Bar",
            "default": "false"
        "BookmarksMenuIncludesAddressBook": {
            "type": "boolean",
            "title": "Bookmarks Menu includes Contacts",
            "default": "false"
        "BookmarksMenuIncludesRendezvous": {
            "type": "boolean",
            "title": "Bookmarks Menu includes Bonjour",
            "default": "false"
        "BookmarksCollectionsIncludeAddressBook": {
            "type": "boolean",
            "title": "Bookmark Collections include Contacts",
            "default": "true"
        "BookmarksCollectionsIncludeRendezvous": {
            "type": "boolean",
            "title": "Bookmark Collections include Bonjour",
            "default": "true"
        "AutoFillFromAddressBook": {
            "type": "boolean",
            "title": "AutoFill web forms using information from contacts",
            "default": "true"
        "AutoFillPasswords": {
            "type": "boolean",
            "title": "AutoFill user names and passwords",
            "default": "false"
        "com.apple.Safari.ContentPageGroupIdentifier.WebKit2ApplePayEnabled": {
            "type": "boolean",
            "title": "AutoFill credit card and Apple Pay data",
            "default": "true"
        "AutoFillMiscellaneousForms": {
            "type": "boolean",
            "title": "AutoFill other forms",
            "default": "true"
        "com.apple.Safari.ContentPageGroupIdentifier.WebKit2PluginsEnabled": {
            "type": "boolean",
            "title": "Enable Plug-ins",
            "default": "true"
        "com.apple.Safari.ContentPageGroupIdentifier.WebKit2JavaEnabled": {
            "type": "boolean",
            "title": "Enable Java",
            "default": "true"
        "com.apple.Safari.ContentPageGroupIdentifier.WebKit2JavaScriptEnabled": {
            "type": "boolean",
            "title": "Enable JavaScript",
            "default": "true"
        "com.apple.Safari.ContentPageGroupIdentifier.WebKit2JavaScriptCanOpenWindowsAutomatically": {
            "type": "boolean",
            "title": "Allow JavaScript to open windows automatically",
            "default": "false"
        "AskBeforeSubmittingInsecureForms": {
            "type": "boolean",
            "title": "Ask before submitting insecure forms",
            "default": "true"
        "com.apple.Safari.ContentPageGroupIdentifier.WebKit2PrivateBrowsingEnabled": {
            "type": "boolean",
            "title": "Private browsing",
            "default": "false"
        "BlockStoragePolicy": {
            "type": "number",
            "title": "Block cookies and website data",
            "description": "0 = Always, 1 = Never, 2 = Third parties except sites you visit, 3 = All third parties",
            "enum": [0, 1, 2, 3]
        "SendDoNotTrackHTTPHeader": {
            "type": "boolean",
            "title": "Website tracking",
            "description": "Prevent cross-site tracking",
            "default": "true"
        "ExtensionsEnabled": {
            "type": "boolean",
            "title": "Enable Extensions",
            "default": "true"
        "DidDisableIndividualExtensionsAfterRemovingOnOffSwitchIfNecessary": {
            "type": "boolean",
            "title": "Disable Extensions immediately",
            "default": "false"
        "LocalFileRestrictionsEnabled": {
            "type": "boolean",
            "title": "Enable local file restrictions",
            "default": "true"
        "CanPromptForPushNotifications": {
            "type": "boolean",
            "title": "Allow Notifications",
            "default": "true"
        "com.apple.Safari.ContentPageGroupIdentifier.WebKit2LoadsImagesAutomatically": {
            "type": "boolean",
            "title": "Display images",
            "default": "true"
        "com.apple.Safari.ContentPageGroupIdentifier.WebKit2TabsToLinks": {
            "type": "boolean",
            "title": "Press Tab to highlight each item on a webpage",
            "default": "false"
        "IncludeDevelopMenu": {
            "type": "boolean",
            "title": "Show Develop menu in menu bar",
            "default": "false"
        "com.apple.Safari.ContentPageGroupIdentifier.WebKit2DefaultTextEncodingName": {
            "type": "string",
            "title": "Default text encoding",
            "description": "The name of the text encoding to use for webpages that don't specify a text encoding. See http://www.iana.org/assignments/character-sets",
            "examples": ["US-ASCII", "macintosh", "Adobe-Standard-Encoding"]
        "com.apple.Safari.ContentPageGroupIdentifier.WebKit2MinimumFontSize": {
            "type": "number",
            "title": "Never use fonts smaller than:",
            "minimum": 1,
            "default": 9
        "com.apple.Safari.ContentPageGroupIdentifier.WebKit2StandardFontFamily": {
            "type": "string",
            "title": "Default font",
            "description": "Font family to use when a webpage does not specify a font.",
            "examples": ["Helvetica", "Verdana", "Times"]
        "com.apple.Safari.ContentPageGroupIdentifier.WebKit2DefaultFontSize": {
            "type": "number",
            "title": "Default font size",
            "description": "Font size to use when a webpage does not specify a font size.",
            "minimum": 1,
            "default": 9
        "com.apple.Safari.ContentPageGroupIdentifier.WebKit2FixedFontFamily": {
            "type": "string",
            "title": "Default fixed-width font family",
            "description": "Font family to use when a webpage specifies fixed-width font."
        "com.apple.Safari.ContentPageGroupIdentifier.WebKit2DefaultFixedFontSize": {
            "type": "number",
            "title": "Default fixed-width font size",
            "description": "Font size to use when a webpage specifies fixed-width font.",
            "minimum": 1,
            "default": 9
        "DefaultDatabaseQuota": {
            "type": "number",
            "title": "Default space for database storage",
            "description": "In bytes",
            "enum": [0, 1048576, 5242880, 10485760, 52428800, 104857600, 524288000],
            "default": 5242880
        "com.apple.Safari.ContentPageGroupIdentifier.WebKit2ShouldPrintBackgrounds": {
            "type": "boolean",
            "title": "Print backgrounds",
            "default": "false"
        "PrintHeadersAndFooters": {
            "type": "boolean",
            "title": "Print headers and footers",
            "default": "true"
noahdowd
  • February 20, 2020
Better Firefox one:
    "title": "org.mozilla.firefox",
    "definitions": {
        "bookmark": {
            "type": "object",
            "title": "Bookmark",
            "properties": {
                "Folder": {"type": "string", "title": "Folder"},
                "URL": {"type": "string", "title": "URL"},
                "Title": {"type": "string", "title": "Title"},
                "Favicon": {"type": "string", "title": "Favicon"},
                "Placement": {"type": "string", "title": "Placement"}
        "extension": {
            "type": "object",
            "title": "Extension",
            "properties": {
                    "type": "string",
                    "title": "Installation Mode",
                    "default": "blocked",
                    "enum": ["allowed", "blocked", "force_installed", "normal_installed"]
                "install_url": {
                    "type": "string",
                    "description": "The location of the extension to be installed.",
                    "title": "Install URL"
                    "type": "array",
                    "title": "Install Sources",
                    "items": {"type": "string", "title": "URL"}
                    "type": "string",
                    "title": "Blocked Install Message",
                    "description": "Error message to display to users if they're blocked from installing an extension."
    "type": "object",
    "properties": {
            "type": "boolean",
            "title": "Disable Desktop Background",
            "default": "true"
        "Preferences": {
            "type": "object",
            "title": "Preferences",
            "properties": {
                "app.update.auto": {"type": "boolean", "title": "Enable Auto Update", "default": "true"},
                "security.default_personal_cert": {"type": "string", "title": "Default Personal Certificate", "default": "Ask Every Time"}
        "DisableProfileImport": {"type": "boolean", "title": "Disable Profile Importing", "default": "true"},
            "type": "object",
            "title": "Security Bypass Settings",
            "properties": {
               "InvalidCertificate": {"type": "boolean", "title": "Disable Invalid SSL Cert Bypass", "default": "true"},
               "SafeBrowsing": {"type": "boolean", "title": "Allow Safe Browsing", "default": "true"}
        "DNSOverHTTPS":{
            "type": "object",
            "title": "DNS Over HTTPS",
            "properties": {
               "Enabled": {"type": "boolean", "title": "Enabled", "default": "false"},
               "Locked": { "type": "boolean", "title": "Locked", "default": "true"},
               "ProviderURL": { "type": "string", "title": "Provider URL", "default": "URL_TO_ALTERNATE_PROVIDER" }
        "CaptivePortal": { "type": "boolean", "title": "Captive Portal", "default": "false" },
        "DisableAppUpdate": { "type": "boolean", "title": "Disable App Update", "default": "true" },
        "DefaultDownloadDirectory": { "type": "string", "title": "Default Download Directory", "default": "${home}/Downloads" },
        "DontCheckDefaultBrowser": { "type": "boolean", "title": "Don't Check Default Browser", "default": "true" },
        "Certificates":{
            "type": "object",
            "title": "Certificates",
            "properties": {
               "Install": {
                "type": "array",
                "title": "Install",
               "ImportEnterpriseRoots": { "type": "boolean", "title": "Import Enterprise Root CAs", "default": "true" }
        "Homepage":{
            "type": "object",
            "properties": {
               "URL": { "type": "string", "title": "URL", "default": "http://example.com" },
               "Additional": {
                "type": "array",
                "title": "Additional Tabs",
                    "items": {"type": "string", "title": "URL"},
               "Locked": { "type": "boolean", "title": "Locked", "default": "true" },
                "StartPage": { "type": "string", "title": "Start Page", "default": "homepage", "enum": ["none", "homepage", "previous-session"]}
        "DisableFormHistory": { "type": "boolean", "title": "Disable Form History", "description": "Turn off saving information on web forms and the search bar.", "default": "true" },
        "SupportMenu":{
            "type": "object",
            "title": "Support Menu",
            "description": "Add a menuitem to the help menu for specifying support information.",
            "properties": {
               "Title": { "type": "string", "title": "Window Title", "default": "Click here for help" },
               "URL": { "type": "string", "title": "URL", "default": "http://example.edu/" },
               "AccessKey": { "type": "string", "title": "Keyboard Key to Access", "default": "C" }
        "DisableSafeMode": { "type": "boolean", "title": "Disable Safe Mode", "default": "true" },
        "ExtensionUpdate": { "type": "boolean", "title": "Allow Extension Updates", "default": "false" },
        "DisableSystemAddonUpdate": { "type": "boolean", "title": "Disable System Add-On Updates", "default": "true" },
        "DisableFirefoxScreenshots": { "type": "boolean", "title": "Disable Firefox Screenshots", "default": "true"},
        "FlashPlugin":{
            "type": "object",
            "title": "Adobe Flash Plugin",
            "properties": {
                "Allow": {
                    "type": "array",
                    "title": "Allow",
               "Block": {
                    "type": "array",
                    "title": "Block",
               "Default": { "type": "boolean", "title": "Default", "default": "true" },
        "DisableFirefoxAccounts": { "type": "boolean", "title": "Disable Firefox Accounts", "default": "true" },
            "type": "array",
            "title": "Extension Settings",
            "items": [{
                "type": "object",
                "properties": {
                        "type": "object",
                        "title": "All Extensions",
                        "properties": {
                                "type": "string",
                                "type": "array",
                                "title": "Install Source URLs",
                                "type": "string",
                            "allowed_types": {
                                "type": "array",
                                "title": "Allowed Types",
                                "items": {"type": "string", "enum": ["extension", "theme", "dictionary", "langpack"]}
            "additionalItems": {"$ref": "#/definitions/extension"}
        "DisplayBookmarksToolbar": { "type": "boolean", "title": "Display Bookmarks Toolbar", "default": "true" },
        "HardwareAcceleration": { "type": "boolean", "title": "Enable Hardware Acceleration", "default": "false" },
        "DisablePrivateBrowsing": { "type": "boolean", "title": "Disable Private Browsing", "default": "true" },
        "EnterprisePoliciesEnabled": { "type": "boolean", "title": "Enable Enterprise Policies", "description": "Enable policy support on macOS.", "default": "false" },
        "Bookmarks": {
            "type": "array",
            "title": "Bookmarks",
        "NetworkPrediction": { "type": "boolean", "title": "Network Prediction", "description": "Enable or disable network prediction (DNS prefetching).", "default": "false" },
            "type": "object",
            "title": "Tracking Protection",
            "properties": {
               "Fingerprinting": { "type": "boolean", "title": "Fingerprinting", "default": "true" },
               "Value": { "type": "boolean", "title": "Trackers", "default": "true" },
               "Cryptomining": { "type": "boolean", "title": "Cryptomining", "default": "true" }
        "OverrideFirstRunPage": {"type": "string", "title": "First Run Page", "default": "https://www.example.com"},
        "Extensions":{
            "type": "object",
            "title": "Extensions",
            "properties": {
               "Install": {
                "type": "array",
                "title": "Install",
               "Uninstall": {
                "type": "array",
                "title": "Uninstall",
                "items": {"type": "string", "title": "Extension ID"},
                "default": []
               "Locked":
                "type": "array",
                "title": "Locked",
        "Authentication":{
            "type": "object",
            "title": "Authentication",
            "properties": {
               "NTLM": {
                "type": "array",
                "title": "NTLM",
                "items": {"type": "string", "title": "Domain"},
               "Delegated": {
                "type": "array",
                "title": "Delegated",
               "AllowNonFQDN":{
                "type": "object",
                "title": "Allow Non-FQDN",
                "properties": {
                    "SPNEGO": { "type": "boolean", "title": "SPNEGO", "default": "true" },
                    "NTLM": { "type": "boolean", "title": "NTLM", "default": "true" }
               "AllowProxies":{
                "type": "object",
                "title": "Allow Proxies",
                "properties": {
               "SPNEGO": {
                "type": "array",
                "title": "SPNEGO",
        "Proxy":{
            "type": "object",
            "title": "Proxy",
            "properties": {
               "Mode": {"type": "string", "title": "Mode", "default": "manual", "enum": ["none", "system", "manual", "autoDetect", "autoConfig"]},
               "HTTPProxy": {"type": "string", "title": "HTTP Proxy", "default": "https://httpproxy.example.com"},
               "UseHTTPProxyForAllProtocols": {
                    "type": "boolean",
                    "title": "Use HTTP Proxy For All Protocols",
                    "default": "false"
                "SSLProxy": {
                    "type": "string",
                    "title": "SSL Proxy",
                    "default": "https://sslproxy.example.com"
                "FTPProxy": {
                    "type": "string",
                    "title": "FTP Proxy",
                    "default": "https://ftpproxy.example.com"
                "SOCKSProxy": {
                    "type": "string",
                    "title": "SOCKS Proxy",
                    "default": "https://socksproxy.example.com"
                "SOCKSVersion": {"type": "string", "title": "Socks Version", "default": "4", "enum": ["4", "5"]},
                "Passthrough": {
                    "type": "array",
                    "title": "Passthrough",
                    "items": {"type": "string", "title": "URL or IP"},
                    "default": ["<local>"]
                "AutoConfigURL": {
                    "type": "string",
                    "title": "Auto Config URL",
                    "description": "URL for proxy configuration (only used if Mode is autoConfig)."
                "AutoLogin": {
                    "type": "boolean",
                    "title": "Auto Login",
                    "description": "Do not prompt for authentication if password is saved.",
                    "default": "false"
                "UseProxyForDNS": {
                    "type": "boolean",
                    "title": "Use Proxy For DNS",
                    "description": "Use proxy DNS when using SOCKS v5.",
                    "default": "false"
        "SecurityDevices":{
            "type": "array",
            "title": "Security Devices",
            "description": "Install PKCS #11 modules.",
            "items": {
                "type": "object",
                "properties": {
                   "key": {"type": "string", "title": "Device Name"},
                   "value": {
                       "type": "string",
                       "title": "Device",
                   "propertyNames": {"type": "string"}
        "OverridePostUpdatePage": {"type": "string", "title": "Post-Update Page", "default": ""},
        "BlockAboutSupport": { "type": "boolean", "title": "Block About Support", "description": "Block access to Troubleshooting Information (about:support).", "default": "true" },
        "LocalFileLinks": {
            "type": "array",
            "title": "Local File Links",
            "description": "Enable linking to local files by origin.",
        "Permissions":{
            "type": "object",
            "title": "Permissions",
            "properties": {
               "Camera":{
                "type": "object",
                "title": "Camera",
                "properties": {
                      "Allow": {
                        "type": "array",
                        "title": "Allow",
                      "BlockNewRequests": { "type": "boolean", "title": "Block New Requests", "default": "true" },
                      "Block": {
                        "type": "array",
                        "title": "Block",
               "Microphone":{
                "type": "object",
                "title": "Microphone",
                "properties": {
                      "Allow": {
                        "type": "array",
                        "title": "Allow",
                      "Block": {
                      "type": "array",
                      "title": "Block",
                      "items": {"type": "string", "title":"URL"},
                      "Locked": { "type": "boolean", "title":"Locked", "default": "true" }
               "Location":{
                "type": "object",
                "title": "Location",
                "properties": {
                      "Allow": {
                        "type": "array",
                        "title": "Allow",
                      "Block": {
                      "type": "array",
                      "title": "Block",
               "Notifications":{
                "type": "object",
                "title": "Notifications",
                "properties": {
                      "Allow": {
                        "type": "array",
                        "title": "Allow",
                      "Block": {
                      "type": "array",
                      "title": "Block",
        "PasswordManagerEnabled": { "type": "boolean", "title": "Password Manager Enabled", "default": "false" },
        "NoDefaultBookmarks": { "type": "boolean", "title": "No Default Bookmarks", "default": "true" },
        "FirefoxHome":{
            "type": "object",
            "title": "Firefox Home",
            "properties": {
               "TopSites": { "type": "boolean", "title": "Top Sites", "default": "true" },
               "Pocket": { "type": "boolean", "title": "Pocket", "default": "false" },
               "Search": { "type": "boolean", "title": "Search", "default": "true" },
               "Snippets": { "type": "boolean", "title": "Snippets", "default": "false" },
               "Highlights": { "type": "boolean", "title": "Highlights", "default": "true" }
        "DisableFeedbackCommands": { "type": "boolean", "title": "Disable Feedback Commands", "description": "Disable the menus for reporting sites.", "default": "true" },
        "DisablePasswordReveal": { "type": "boolean", "title": "Disable Password Reveal", "default": "true" },
        "AppUpdateURL": {"type": "string", "title": "App Update URL", "default": "https://www.example.com/update.xml"},
        "DisableTelemetry": { "type": "boolean", "title": "Disable Telemetry", "default": "true" },
        "DisableDeveloperTools": { "type": "boolean", "title": "Disable Developer Tools", "default": "true" },
        "SearchBar": {"type": "string", "title": "Search Bar", "default": "separate", "enum": ["unified", "separate"]},
        "WebsiteFilter":{
            "type": "object",
            "title": "Website Filter",
            "properties": {
               "Block": {
                "type": "array",
                "title": "Block",
                "items": {"type": "string", "title": "URL" },
               "Exceptions": {
                    "type": "array",
                    "title": "Exceptions",
        "DisableFirefoxStudies": { "type": "boolean", "title": "Disable Firefox Studies", "description": "Disable Firefox studies (Shield).", "default": "true" },
        "DownloadDirectory": {"type": "string", "title": "Download Directory", "default": "${home}/Downloads"},
        "BlockAboutConfig": { "type": "boolean", "title": "Block About Config", "description": "Block access to about:config.", "default": "true" },
        "DisableMasterPasswordCreation": { "type": "boolean", "title": "Disable Master Password Creation", "default": "true" },
        "SanitizeOnShutdown": { "type": "boolean", "title": "Sanitize On Shutdown", "description": "Clear all data on shutdown.", "default": "true" },
            "type": "object",
            "title": "Install Addons Permissions",
            "properties": {
               "Allow": {
                "type": "array",
                "title": "Allow",
               "Default": { "type": "boolean", "title": "Set As Default", "default": "false" }
        "DisablePocket": { "type": "boolean", "title": "Disable Pocket", "description": "Remove Pocket in the Firefox UI.", "default": "true" },
        "DisableBuiltinPDFViewer": { "type": "boolean", "title": "Disable Built-in PDF Viewer", "default": "true" },
        "DisableProfileRefresh": { "type": "boolean", "title": "Disable Profile Refresh", "description": "Disable the Refresh Firefox button on about:support and support.mozilla.org", "default": "true" },
        "NewTabPage": { "type": "boolean", "title": "New Tab Page", "default": "false" },
        "OfferToSaveLoginsDefault": { "type": "boolean", "title": "Offer To Save Logins - Default Value", "description": "Sets the default value of signon.rememberSignons without locking it.", "default": "false" },
        "OfferToSaveLogins": { "type": "boolean", "title": "Offer To Save Logins", "default": "false" },
        "SSLVersionMin": {"type": "string", "title": "SSL Version Minimum", "default": "tls1.3", "enum": ["tls1", "tls1.1", "tls1.2", "tls1.3"]},
        "SSLVersionMax": {"type": "string", "title": "SSL Version Maximum", "default": "tls1.3", "enum": ["tls1", "tls1.1", "tls1.2", "tls1.3"]},
        "BlockAboutAddons": { "type": "boolean", "title": "Block About Addons", "description": "Block access to the Add-ons Manager (about:addons).", "default": "true" },
            "type": "array",
            "title": "Requested Locales",
            "items": {"type": "string", "title": "Locale"},
        "BlockAboutProfiles": { "type": "boolean", "title": "Block About Profiles", "description": "Block access to About Profiles (about:profiles).", "default": "true" },
        "Cookies":{
            "type": "object",
            "title": "Cookies",
            "properties": {
               "ExpireAtSessionEnd": { "type": "boolean", "title": "Expire At Session End", "default": "true" },
               "Default": { "type": "boolean", "title": "Default", "default": "false" },
               "Allow": {
                "type": "array",
                "title": "Allow",
               "RejectTracker": { "type": "boolean", "title": "Reject Tracker", "default": "true" },
               "Block": {
                "type": "array",
                "title": "Block",
               "AcceptThirdParty": {"type": "string", "title": "Accept Third Party", "default": "never", "enum": ["always", "never", "from-visited"]}
        "DisableForgetButton": { "type": "boolean", "title": "Disable Forget Button", "default": "true" },
        "PopupBlocking":{
            "type": "object",
            "title": "Popup Blocking",
            "properties": {
               "Allow": {
                "type": "array",
                "title": "Allow",
  • February 20, 2020
Hey @noahdowd, thanks for posting these custom schemas! These are very cool, and illustrate how useful this new feature can be in the product. Of course, thanks also go to Jamf for adding the feature in in the first place.
But I need to ask, given the complexity of the last schema you just posted above on Firefox, are you using some kind of tool to build these, or are you hand crafting them? I ask because after seeing some of the ones you posted earlier, I began looking into it and starting working on one for NoMAD, which, once I feel it's done I'll post here. Maybe this thread can serve as an initial placeholder for new Custom Application schemas until there's a better repository for them. But I've been making the one I'm working on by hand, and I gotta say, it's a TON of work! Plus, since I'm a total noob on JSON, I have to keep checking my work through an online JSON validator, which tells me if I've formatted something wrong and can correct it.
So, how are you making these? I'd love to find some way to speed up the process if possible. If there isn't one, that's fine, but its just good for anyone else coming here to note that these aren't exactly easy to create if you aren't that familiar with their structure at first.
noahdowd
  • February 20, 2020
Haha nope all by hand! Just BBEdit and this JSON schema validator.
I'm adding things like titles, descriptions, and enums as I learn about them. A tool would be great!
  • February 20, 2020
Ah, ok. Good to know. :) I'm also using BBEdit for my tooling, though I was using a different online JSON validator. Thanks for the link to that one. Good to have options!
In looking at your most recent one, you gave me some ideas on how to better structure the data so I can sort of "group" related items together in more logical sections. I wasn't happy about how each setting was on it's own line and taking up so much space in the final UI. I'd like to put related items, such as naming the menu items for example, in a grouping so they make more sense. I might try to copy off of what you've done. Again, thanks for posting these!
  • February 20, 2020
So could someone explain to those of us who might be considered at times to be slow behind the wheel(so to speak anyways) what is this JSON schema thing you speak of? What does this accomplish?
  • February 20, 2020
@jhuls Valid question. I'm not a JSON person, so I'm only just learning about it. JSON stands for JavaScript Object Notation. It's an open standard for data exchange. But more importantly, what Jamf added in Jamf Pro version 10.19 is a way for us to create JSON schemas that can be used with their relatively new Application & Custom Settings payload.
Once configured, instead of using just the couple of ones that Jamf provides out of the box win their own repository for their own products (Jamf Connect, etc.) and Microsoft Office & AutoUpdate, you can choose Custom Schema now from the list.
Once you do that, you get a few tabs that show up, one called "Schema" that let's you paste in custom JSON formatted text, that can define the options available in a nice GUI way to set up preferences. This is basically another way of creating a Config Profile for something like a 3rd party application. We've always been able to upload a crafted plist with the values we need, and have Jamf Pro read it in, but it's not easily editable in that format, whereas with the new JSON schema, we can add/remove keys, make changes to the values on the fly and so on, without needing to edit a plist file and re-upload it.
Here are some screenshots that show how the one I'm working on looks once it's imported and you click on the "Properties" tab. This is for the application NoMAD.
..and there's more that I'm not showing here, like all the custom icon paths and so on, just because it's too many images. Basically, all the options that are normally in a plist file with keys and values will show up as GUI objects that you can set, and then when saved, the Config Profile is written out so it applies whatever settings you've chosen/set.
Another cool thing with this is that you have a way of adding/removing keys right in the UI. So for example, let's say you don't care about setting the certificate options, specifically the "Get Certificate Automatically" and "Exportable Private Key" items. You can just click the top Add/Remove Properties button and then uncheck those items from the list and they will get removed from both the UI and the final Config Profile.
Pretty cool!
So hopefully that helps to explain a little of why we're discussing this. Again, this is new in 10.19. I'm testing it out under the 10.20 beta because my Jamf cloud instance isn't scheduled to be upgraded until this weekend I believe.
  • February 20, 2020
@mm2270 Thanks a ton for that explanation. We're still on 10.17.1 ourselves but hoping to upgrade in the next couple weeks. This looks like a practical feature to definitely look forward to.
  • February 21, 2020
@mm2270 I agree this is a significant step forward, but it appears to shift the complexity from writing plist files to ... writing JSON files ... with a text editor ... by Jamf admins ... at end user organizations.
What would be ideal, though, is if third party app developers themselves created these JSON files and maintained them over time, and perhaps Jamf Pro could import them.
Admittedly, this approach would open up security concerns (which potentially could be fixed in part by signing the JSON files), but it would have the huge advantage of placing the burden squarely where it belongs, namely on the app developers and MDM providers themselves.
Edited to add: See this link for a fine example of a third party app developer — Microsoft — doing exactly that:
Simplifying Microsoft Edge configuration profiles for Jamf Pro
  • February 21, 2020
@mthakur You'll get no disagreement from me on that. You're right that it does shift this to writing JSON instead of xml or hand crafting .mobileconfig files. I kind of said as much above in my earlier post, that this is definitely NOT for the novice admin.
However, this feature is an attempt to partially fulfill this one, I think. Specifically, if you look at the mock up done by @milesleacy here, it's not all that dissimilar, but it DOES require building the framework in JSON to even be able to use a simple add/remove approach like what he mocked up.
So, while it's not the simple GUI approach we might have all hoped for, I feel it's at least a step in the right direction.
It's a first step, and I think is designed to work in conjunction with some of the other changes Jamf is making around Config Profiles, like the sliders for On/Off states they introduced in a couple of payloads, which will help avoid placing options that we don't even want into a profile.
Eventually it'll all get there, but it's going to take some time and iterations to achieve it.
mscottblake
  • February 21, 2020
A couple of us have been writing these up and posting them to GitHub.
https://github.com/MScottBlake/jamf-custom-schemas
https://github.com/chrisgrande/jamf-profile-schemas
https://github.com/joshua-d-miller/JAMF-JSON-Schema
Chris and I have talked a bit about creating a new team to host these to cut down on duplication of work. @mm2270, I can vouch for how much work the NoMAD one is and I wouldn't wish it on anyone since it's already working (as far as I can tell).
Now that I see you were also working on NoMAD, it's making me want to go create a team now...
Standby while I go get something started.
mscottblake
  • February 21, 2020
We now have a team setup in GitHub at https://github.com/Jamf-Custom-Profile-Schemas so we can group all of the custom schemas in one place and hopefully reduce duplicated effort.
  • February 21, 2020
Haha, and just as I finished (mostly) the NoMAD one I was working on. In looking at yours I can see it uses more advanced options overall in some places. Well, it was a good exercise for me to learn a bit about JSON anyway. I like how yours uses a "Configured/Not Configured" drop down for each item. I didn't even know that was an option (again, noob at JSON that I am). So I can learn from that for the next go around.
I'll check out the other ones too. Glad there's a more central place for these for the moment. Jamf should probably add a place here where they can be uploaded and hosted too, kind of like with Extension Attributes and other resources.
mscottblake
  • February 21, 2020
Yeah, I agree that they should, but in the absence of that, I hope this way works.
mscottblake
  • February 21, 2020
noahdowd
  • February 24, 2020
@mscottblake Oh wow this is great! I'm learning so much from looking these over. Thanks!
  • February 25, 2020
@mscottblake amazing work and thanks for the github. I've myself created one where I store my creations. I use your custom schema for NoMAD and it helps a lot !
I've created one for the notifications : link
mscottblake
  • February 25, 2020
@bp.studer I invited you to the team so you can include your stuff in the central repo. If anyone else wants the same, let me know and I can get you an invite.
  • February 25, 2020
@mscottblake I have one for blacklist/whitelist extensions in Chrome. https://github.com/Ahebrt76/Jamf-Schemas-
  • February 27, 2020
Hey there I created a schema for Munki (here).
Feel free to upload and expand it. I haven't pushed it to git yet.
EDIT: Somebody already has a better one.
  • April 17, 2020
Anyone create any schema's for Google Chrome?
mscottblake
  • April 20, 2020
@seanism I have not and do not plan to do so. Since Chrome is developed by a corporation, it is my hope that they will embrace the technology. My focus is on open source software.
  • June 16, 2020
how we can read this custom schema in our machine once it is deployed successfully?
  • June 16, 2020
@slashnext The custom schema itself doesn't get deployed to any machines. It gets imported into Jamf Pro to create a GUI for you to use to set settings that get deployed to your machines. The settings themselves are no different in the end than any other configuration profile plist.
