Hi ,
I am trying to encrypt the HDD through Jamf in policy and configuration profile but I am getting this error for the machines any suggestion please post
You need to either logout/login which then prompts to enable FV2
Hi
Thanks for the update I have tried it but still the same issue is happing
This was the final troubling shooting I have done
We have tested last week on FileVault 2 encryption, “Deferred enablement appears to be active for user”. Either local account or mobile account is giving this error This issue is not only in 10.15 its giving me the error in 10.14 and also in 10.13 I have tried the following steps but still not achieved the FileVault encryption 1.Tried terminal command sudo fdesetup disable and sudo fdesetup staus i was getting the error 2.Formated with a new OS and tried to created a new mobile account with has a secure token enabled but still getting the same error with new setup 3.We tried with Custom Plist file to address the Deferred enablement issue but nothing change. Attached the Pilist 4.Configured via Configuration Profile and getting an error “There was a problem enabling Filevault on your computer”. 5.Deployed via policy and FV2 is not triggered at login 6.checked the secure token for the user YES the secure token is present through a terminal command sysadminctl -secureTokenStatus Username 7.tried enabling the fileVault from manually but still found different errors in different machines “Unable to communicate the server “ and “There was a problem enabling Filevault on your computer please go to security and privacy for more details
thanks and regards
Ajay
hi
please find the error messages
