Disabling camera in certain applications
  • March 13, 2019
  • 13 views
Hi all,
I received a request from a client and I can't quite figure out if it is possible. Is there a way to disable camera usage in select apps while leaving it available in others? For example, I do not want my users to have camera access in Facebook but would like them to be able to use it for Facetime or a specific medical application.
Can that be done with JAMF?
Best answer by sshort
The camera restrictions in iOS are all-or-nothing at the moment.
Hugonaut
Forum|alt.badge.img+15
  • March 13, 2019
I've never tried it out but sounds like something the PPPC Utility could do. - https://github.com/jamf/PPPC-Utility
  • Edit: excuse my lack of coffee - this is for iOS not macOS I take it - ignore my comment that being the case
  • March 13, 2019
