A bluetooth device that is not mine try to connect on my MacBook pro every minutes.
This has the consequence of disconnecting me for a few seconds from my bluetooth devices.
I've tried - Disable Bluetooth
  • Delete "com.apple.Bluetooth.plist" from "Library/Preferences" and "ByHost" folders
  • plutil -convert xml1 /Library/Preferences/com.apple.Bluetooth.plist
  • Add this section to the plist:
    <key>IgnoredDevices</key>
    <array> <string>MAC ADRESS</string>
    </array>
  • sudo plutil -convert binary1 /Library/Preferences/com.apple.Bluetooth.plist
  • Reboot
  • Enable Bluetooth
But my changes to this plist get reverted back and the device appears again.
Please, can you help me...
MacOS 10.13.6 / Jamf 10.6.0
Thanks
Dated post, so you've probably solved the issue?? If not, I would suggest an nvram reset, either holding the command option p r keys on startup, or in the Terminal: nvram -xp & reboot.
See View & Clear the Mac NVRAM Contents
