Hey Everyone,
I'm having an issue where I can unable to change the NTP server to what I want.
The NTP time stuck in system preferences, even after unenroll. I change it via terminal using the sudo systemsetup -setnetworktimeserver time.euro.apple.com but it reverts back.
I'm thinking there is a stuck setting but I can't find the plist or setting.
Does anyone have any ideas?
