9.98 Disallow TouchID for macOS
  • March 22, 2017
  • 51 views
DBrowning
Installed 9.98 in my test environment, and set a device policy to no allow touch ID to work. Yet it still works.... anyone else see this?
Best answer by stevehahn
If I'm not mistaken, the ability to block Touch ID by config profile is coming in 10.12.4--so if your client Mac is on 10.12.3 or earlier the profile won't do anything.
  • March 23, 2017
donmontalvo
Forum|alt.badge.img+36
  • March 23, 2017
10.12.4 Beta 8 came out a few days ago, wouldn't be surprised to see it drop in the coming days.
DBrowning
  • March 23, 2017
tested on a machine with 10.12.4 beta 8 this morning and it works.
If someone already has touchID enabled, it disables but doesn't prevent access to the System Pref. When waking the machine from sleep or screen saver, there is just a note "Your password is required to enable TouchID".
I was able to make that message go away by running sudo bioutil -w -f 0 -s
which will disable the touchID functionality system wide.
