MYSQL Dump with SSL
  • October 28, 2016
  • 0 replies
  • 23 views
Ok so here is what im trying to do. We have setup our MySQL instance to use ssl and all is well, but it breaks the backup function of the jssdb utility. As there is no SSL option for it.
So im trying to write a batch script to emulate that ability. but im running into alot of issues.. i found the following script and tried to modify it a tad and while it creates the .sql file it doesn't actually connect to the database i just get the following error "mysqldump: Got error: 2026: SSL connection error: SSL_CTX_set_default_verify_paths failed when trying to connect"
--------------------Script ------------
:: Auto MySQL Backup For Windows Servers By Matt Moeller v.1.5
:: RED OLIVE INC. - www.redolive.com
:: Follow us on twitter for updates to this script twitter.com/redolivedesign
:: coming soon: email admin a synopsis of the backup with total file size(s) and time it took to execute
:: FILE HISTORY ----------------------------------------------
:: UPDATE 11.7.2012 Added setup all folder paths into variables at the top of the script to ease deployment
:: UPDATE 7.16.2012 Added --routines, fix for dashes in filename, and fix for regional time settings
:: UPDATE 3.30.2012 Added error logging to help troubleshoot databases backup errors. --log-error="c:MySQLBackupsackupfilesdumperrors.txt"
:: UPDATE 12.29.2011 Added time bug fix and remote FTP options - Thanks to Kamil Tomas :: UPDATE 5.09.2011 v 1.0
:: If the time is less than two digits insert a zero so there is no space to break the filename
:: If you have any regional date/time issues call this include: getdate.cmd credit: Simon Sheppard for this cmd - untested
:: call getdate.cmd
set year=%DATE:~10,4%
set day=%DATE:~7,2%
set mnt=%DATE:~4,2%
set hr=%TIME:~0,2%
set min=%TIME:~3,2%
IF %day% LSS 10 SET day=0%day:~1,1%
IF %mnt% LSS 10 SET mnt=0%mnt:~1,1%
IF %hr% LSS 10 SET hr=0%hr:~1,1%
IF %min% LSS 10 SET min=0%min:~1,1%
set backuptime=%year%-%day%-%mnt%-%hr%-%min%
echo %backuptime%
:: SETTINGS AND PATHS :: Note: Do not put spaces before the equal signs or variables will fail
:: Name of the database user with rights to all tables
set dbuser=BDBackup
:: Password for the database user
set dbpass=notmyrealpassword
:: SSL Cert location
set CertPath="C:Program FilesMySQLMySQL Server 5.6certificatescerts
:: Error log path - Important in debugging your issues
set errorLogPath="E:JSS DB Backupsackupfilesdumperrors.txt"
:: MySQL EXE Path
set mysqldumpexe="C:Program FilesMySQLMySQL Server 5.6inmysqldump.exe"
:: BackupPath
set backupfldr=E:JSS DB Backups
:: Path to data folder which may differ from install dir
set datafldr="C:ProgramDataMySQLMySQL Server 5.6data"
:: Path to zip executable
set zipper="c:MySQLBackupszip7za.exe"
:: Number of days to retain .zip backup files set retaindays=15
:: DONE WITH SETTINGS
:: GO FORTH AND BACKUP EVERYTHING!
:: Switch to the data directory to enumerate the folders
pushd %datafldr%
echo "Pass each name to mysqldump.exe and output an individual .sql file for each"
:: Thanks to Radek Dolezel for adding the support for dashes in the db name
:: Added --routines thanks for the suggestion Angel
:: turn on if you are debugging
@echo off
FOR /D %%F IN (*) DO (
IF NOT [%%F]==[performance_schema] (
SET %%F=!%%F:@002d=-!
%mysqldumpexe% --user=%dbuser% --password=%dbpass% --ssl --ssl-ca=%CertPath%ca.pem" --ssl-cert=%CertPath%client-cert.pem” --ssl-key=%CertPath%client-key.pem --databases --routines --log-error=%errorLogPath% %%F > "%backupfldr%%%F.%backuptime%.sql"
) ELSE (
echo Skipping DB backup for performance_schema
echo "Zipping all files ending in .sql in the folder"
:: .zip option clean but not as compressed
%zipper% a -tzip "%backupfldr%FullBackup.%backuptime%.zip" "%backupfldr%*.sql"
echo "Deleting all the files ending in .sql only"
del "%backupfldr%*.sql"
::echo "Deleting zip files older than 30 days now"
::PForfiles -p %backupfldr% -s -m . -d -%retaindays% -c "cmd /c del /q @path"
echo "done"
::return to the main script dir on end
popd
