Export computer usage for multiple imacs
  • May 30, 2018
  • 11 views
We feel that our imacs aren't optimally used in our business and we think we can get rid of some. I can check our systems computer usage one by one but this is not very functional. So i was wondering:
Is it possible to make an export of the computer usage logs of all our imacs at once?
1 reply
Tangentism
  • May 30, 2018
You'll have to look at doing this either through the API or heading straight to the SQL server.
With the API have a look at https://[your.jss.url]/api/#!/computerapplicationusage
or tips to access the SQL:
Below are a couple of resources about accessing the API & scripting:
https://bryson3gps.wordpress.com/2014/03/30/the-jss-rest-api-for-everyone/
https://github.com/beyondthebox/JSS-Resource-Tools
