Some background: we've been successfully pushing custom Chrome settings to our Macs using custom config profiles for some time. The original XML/plists have been composed using keys and settings from https://www.chromium.org/administrators/policy-list-3 --
We've had 100% success so far pushing extensions, settings, blocked extensions, etc, but we cannot get this particular setting to enforce.
"SitePerProcess"
We are testing Chrome's Strict Site Isolation setting as a band-aid for Spectre until Google releases a remediated version of Chrome. (Yes, I realize Safari and Firefox are alternatives, but the impetus on this issue comes from our end users, long story.)
Has anyone had issues, in general, using custom config profiles like this for Chrome, and if so, has anyone had luck troubleshooting any non-working profiles? It's usually a syntax thing, and the profile either works or not...
Here's a simple .xml with nothing but that payload. The JSS interprets the file just fine, showing me the key and subsequent value on the profile page, but alas, client computers do not reflect the change.
Any ideas? And thanks in advance for taking a look at this, anyone!
<plist version="1.0">
<dict>
<key>SitePerProcess</key>
<true />
</dict>
</plist>
