Hi all,
We are rolling out new iPhones to our users. We have the phones enrolled in DEP and scoped to the prestage enrollment in JSS.
If we set the phone up as a new phone, the enrollment works perfectly every time. This proves connectivity to the JSS is fine, and the prestage enrollment is setup correctly.
If we restore from iCloud, it get's stuck at "Installing configuration for ...". Packet capture on the JSS shows that it connects through after entering JSS credentials, but then once it starts installing the configuration it will stop with zero traffic to the JSS from that point on...forever.
I've done some reading on here, and some older threads mention it not being possible to restore iCloud backup in addition to DEP + Prestage enrollment. This would be disappointing with the latest versions of everything.
Edit: I can also confirm that restoring from iTunes backup results in the same issue. Stuck at "Installing configuration from..." with no data being sent to or received from the JSS.
Anyone out there successfully doing this, or am I dreaming?
Cheers,
Gavin
