Jamf Pro - Pushing .pkg and failing?
  • February 25, 2020
  • 0 replies
  • 9 views
Hello Jamf Nation! I'm having a bit of an issue here. I created a pkg in composer to push a script file to /private/tmp and having a postinstall script run it, although in jamf dashboard it shows that it failed. I went to check the machine and it shows that the script ran successfully and Digital Guardian Agent has been installed, but the dashboard says it failed, any ideas?
Even though knowing that DG Agent was installed, it would be hard for me to keep track of what machine it was successfully installed on if the dashboard in jamf is telling me it failed when I know it didn't.
