AD binding script that allows user to pick OU
  • August 15, 2017
  • 11 replies
  • 89 views
I'm wondering if anyone knows or has stumbled upon a script for Binding to AD that prompts to select an OU out of multiple selections. I work for a company that has multiple department OUs. The Windows side has a power shell script that prompts the user to select the OU, I would love to have something similar on the Mac side. I did some searching around to no avail, my guess is that there might be a better way to do this that I'm not considering. Any help on this would be greatly appreciated :)
Best answer by koalatee
I do this with cocoa dialog, we have 3 main OUs with several OUs inside those (with OUs inside those, with OUs inside those...), so I let people choose and it drills down each time.
Definitely didn't want to hardcode anything in, so using ldapsearch to search OUs
**edit: just sanitized my script and put the whole thing here, with a few comments
  • August 15, 2017
It should be possible to do. Applescript calls can display a list of items to choose from and the user selection is returned back to the script, which you should then be able to pipe into the dsconfigad command to bind the Mac.
You'd need to be sure you're using binding credentials in your script that can bind a Mac to any of the OUs you need to offer. I would suggest considering putting in script parameters to have the creds passed to the script, rather than having them baked into the script itself, for security reasons.
If you need a script example on how to do this, I can put something up here.
It's possible such a script would need to run with user interaction, which sometimes gets complicated to do when the script is run as root, so that might be a consideration to keep in mind.
bpavlov
  • August 15, 2017
I'll offer 2 alternatives one of which is a variation of what @mm2270 suggested.
  1. Use AppleScript to display a list of OUs. In the JSS create a directory service binding for each OU. Then create a separate JSS policy for each of those bindings. And in your script on the computer, based on what the end user picks via the AppleScript dialog simply reference the JSS policy so that it can proceed to bind to AD. This avoids having to hardcode any password into a script or even putting them into JSS parameter fields which are not encrypted.
  2. Create a generic OU for all Macs to join. On the server side of things, have a powershell script that runs periodically and moves Macs to the appropriate OU.
  • August 15, 2017
To build on these great ideas, if your users log into their Macs with AD accounts and you have setup your AD mappings correctly in the JSS LDAP settings, you should already be storing each user's department in your JSS computer inventory records. You could one up the PowerShell side of the house by using the JSS API to build a script that references the appropriate department from JSS inventory and then automagically chooses the appropriate OU when it is time to bind...
  • August 15, 2017
I had to do this but for different domains, not OUs, but I think it would work if you had a binding defined in the JSS for each OU. The script uses the API to get the list of directory bindings. A drop down list is made from that API data. The submit button triggers the appropriate binding policy.
Sounds similar to what someone else described. I used PHP and Cocoa Dialog to do it. If you're interested, let me know.
  • August 15, 2017
  • August 17, 2017
Thank you all! This really helped me wrap my head around how this should or could work. Much Appreciated! @koalatee thanks for posting your script here, I'm going to give this a shot :)
  • August 18, 2017
@koalatee It appears that this script is working exactly how I want it to, so thanks again! But I have one more question for you. It is giving me a lovely drop down list displaying all of my OUs. However, any OU that has a space are being treated as two different selections, I've looked though the script, but I can't seem to figure out how to get this to display properly., do you know how I could accomplish this? You can probably tell I'm new to shell scripts :)
  • August 18, 2017
@isenorma ah, yeah our OUs are all one string. We use periods (.) instead of spaces :)
One thing I do for API scripts in bash is to initially replace spaces with underscore (_) for display, then change it back when the selection is complete. I generally have issues with arrays with strings that have spaces in bash... there are ways you're supposed to be able to but I never have great success.
  • August 23, 2017
One more question for you @koalatee . I was able to get this partially working by manually entering in my OUs in --items of the cocoadialog section of the OU drop down list, i just had to quote each entry. all looks good now, but I don't actually see anything in the script to do the binding, all I'm seeing is this:
# Bind to AD #
# something needed for how our user groups are set up
if [[ "$OU_One" =~ "group 1" ]] || [[ "$OU_One" =~ "group 2" ]]; then echo "Not group 3, user group will be $domain$OU_One.OUusers" Ask_User="$OU_One"
else echo "group 3, user group will be $domain$OU_UserGroup.OUusers" Ask_User="$OU_UserGroup"
It looks like this just attempts to give the user access to the OU? Not sure. I'm wondering if the bind part got sanitized? I've been looking at this for awhile, so I might just be going crazy. :)
  • August 23, 2017
@isenorma Actual binding happens in line 450 with dsconfigad. You shouldn't need to manually enter OUs, that's part of the whole point of the script ¯_(ツ)_/¯
To your question about user groups, that's to help decide which group to give admin access to. By default, it gives the OU.Admin group (we have 3 main sites within our OU) and the OU.Users group for either the main site OU or the individual OU. It's confusing, I know... but that is set in line 461.
  • August 23, 2017
@isenorma Look at line 37, say your dc is named my.company.server.com and you're trying to bind to the computersmac OU. Line 37 would look like:
DomainC="ou=mac,ou=computers,dc=my,dc=company,dc=server,dc=com"
