share connect
  • June 3, 2018
  • 0 replies
  • 14 views
Hi i am using a shareconnect script by david ackland to mount smb shares, the script runs ok and i am testing with a smb test share, i am not using AD to authenticate just the users local login
the script runs i get the authentication window i put in the credentials and it looks like it should work but it does not mount the share on the desktop if i manually do it using connect to server it works ok does anyone have any ideas
he has a youtube video and i have followed it as instructed
!/bin/bash
Created by David Acland - Amsys
Use at your own risk. Amsys will accept
no responsibility for loss or damage
caused by this script.
username="$3" if [ -z "$username" ]; then # Checks if the variable is empty (user running script from Self Service) username="$USER" fi echo "User: $username"
protocol="$4" # This is the protocol to connect with (afp | smb) echo "Protocol: $4"
serverName="$5" # This is the address of the server, e.g. my.fileserver.com echo "Server: $5"
shareName="$6" # This is the name of the share to mount echo "Sharename: $6"
group="$7" # This is the name of the group the user needs to be a member of to mount the share echo "Group: $7"
Check that the user is in the necessary group
groupCheck=dseditgroup -o checkmember -m $username "$group" | grep -c "yes" if [ "${groupCheck}" -ne 1 ]; then exit 1 fi
Mount the drive
mount_script=`/usr/bin/osascript > /dev/null << EOT tell application "Finder" activate mount volume "$protocol://${serverName}/${shareName}" end tell
EOT`
