Issue in Installer Certificate for User-Initiated Enrollment QuickAdd Package
  • November 2, 2016
  • 19 views
karthikeyan_mac
Forum|alt.badge.img+20
I am working on adding the Mac Developer Installer certificate to JSS User Initiated Enrollment QuickAdd package.
I have created the "Developer ID Installer" Certificate through Xcode following the apple article:-
https://developer.apple.com/library/content/documentation/IDEs/Conceptual/AppDistributionGuide/DistributingApplicationsOutside/DistributingApplicationsOutside.html
We added the developer certificate(.p12) in User Initiated enrollment settings in JSS but when I download the package through enrollment page in fresh new macOS (10.11 & 10.12) still the package is blocked by GateKeeper as unidentified developer or some time shows as package is corrupted or damaged..
If I check the package with pkgutil --check-signature /path/to/package, it shows the package is signed by a developer certificate issued by Apple and other three certificate chain(3rd Party Mac Developer Installer, Apple Worldwide Developer Relations Certification Authority and Apple Root CA).
I am also able to use the certificate with Composer to sign the packages and the composer package is not blocked by gatekeeper.
Am I missing something or Is there any steps to be followed to sign the User Initiated QuickAdd package?
JSS Version:- 9.96 running in RHEL 7.
Thanks & Regards,
Karthikeyan
1 reply
  • November 17, 2016
I have a similar issue. When I first open the quickadd package it gives me gatekeeper warning, but then I click cancel and it opens the installer. Then I can quite and open the installer with no issues. Check and signatures are there.
