Find computers using iCloud Drive
  • November 3, 2016
  • 9 replies
  • 62 views
I'd like to start preparing to upgrade our computers to Sierra and one of the major no no's is allowing the user to enable iCloud Desktop & Documents. Currently there is not a way (that I know of) to turn this off, but keep iCloud drive off. While I don't think that many of our users use iCloud Drive, I would like to set up an EA that could tell me how many users currently use it. Because I will be completely turning iCloud Drive off when users upgrade.
The Plist that shows this is MobileMeAccounts.plist in ~/Library/Preferences/
The trouble is how to identify that it is enabled via a script. The key that shows if it is enabled is above the string. I can't seem to figure out how to look for it. Or maybe there is an easier way!
     <dict>
        <key>Enabled</key>
        <false/>
        <key>Name</key>
        <string>MOBILE_DOCUMENTS</string>
        <key>ServiceID</key>
        <string>com.apple.Dataclass.Ubiquity</string>
        <key>apsEnv</key>
        <string>production</string>
        <key>authMechanism</key>
        <string>token</string>
        <key>iCloudHomeShouldEnable</key>
        <false/>
        <key>url</key>
        <string>https://p48-ubiquity.icloud.com:443</string>
        <key>wsUrl</key>
        <string>https://p48-ubiquityws.icloud.com:443</string>
     </dict>
I realize that this might be a tough question, but I am hoping someone is better than I am at using pListBuddy, awk, grep, etc..
Best answer by iJake
I wrote this EA for us to track iCloud Drive enablement
iCloudDrivePath="/Library/Mobile Documents/com~apple~CloudDocs"
grabConsoleUserAndHome()
currentUser=$(stat -f %Su "/dev/console")
homeFolder=$(dscl . read "/Users/$currentUser" NFSHomeDirectory | cut -d: -f 2 | sed 's/^ *//'| tr -d '
  case "$homeFolder" in
           homeFolder=$(printf %q "$homeFolder")
esac
if [[ "$currentUser" == "root" ]]
    then
        exit
if [[ -e "$homeFolder""$iCloudDrivePath" ]]
    then
        echo "<result>true</result>"
        echo "<result>false</result>"
iJake
Forum|alt.badge.img+23
  • November 3, 2016
esac
    then
        exit
    then
  • November 3, 2016
Awesome! I didn't even think to go the route of looking for the folder rather then trying to parse this plist. Works like a charm! Thanks!
iJake
  • November 3, 2016
@danshaw Glad to help!
daniel_ross
Forum|alt.badge.img+20
  • January 29, 2017
@iJake this absolutely perfect! Wish we had some way to award points for solutions (Suggesting it for the site features).
  • February 10, 2017
Works like a charm. Thank you, @iJake
  • February 13, 2018
Thanks for posting this script @iJake On a more granular level, is there a way to find out if a user has the Desktop & Documents folder option enabled for iCloud drive? I'm not sure what plist that preference is being written to.
  • August 6, 2019
how are you guys dealing with users that already have icloud drive enabled more of what do you guys do with their data?
  • September 5, 2019
Anyone ever find a way to find out which users have Desktop and Documents folders being actively synced to iCloud drive?
  • September 5, 2019
@macmanmk, @alexyu650 & @techmchs,
I modified a script which was originally found elsewhere here on JamfNation that does just this. See near the bottom of the page, here:
Search criteria for computers that have Desktop and Documents in the cloud?
So far, it's been working 100% in my environment.
