I'm desperately trying to solve a problem and keep hitting brick walls.
I need to migrate about 300 users into the Casper JSS. They are not in DEP and will need to be enrolled by invitation.
They are all encrypted already and i'm trying to issue new recovery keys that will get stored in the JSS.
I've tried this: https://github.com/homebysix/jss-filevault-reissue
Which gets stuck in a loop after initial screen and then says they entered their password wrong without actually prompting for the user password
I've also tried this: https://github.com/JAMFSupport/FileVault2_Scripts/blob/master/reissueKey.sh
Which will work locally on the machine when i run it via terminal but when i run it as a script in Casper to the target machine nothing happens - no prompt for password etc.
Anyone managed to do this? Any ideas what's going wrong?
I'm stuck!
