SCEP MobileConfig Creation
  • August 23, 2017
  • 6 replies
  • 75 views
UPDATED: This updated version includes notes on what is being used, why, and where
Any who uses SCEP and is wanting to push it as a Policy, rather than a profile, here is a script for you all.
This was developed by myself and @bash
# TITLE: Computer SCEP mobileconfig
# DESCRIPTION: Script to create a SCEP mobileconfig
#              for any company that uses SCEP for Macs
# AUTHOR: Created by Bryan Feuling and Sean Boult
# Gets current User ID and Computer Name
CURRUSER=`/bin/ls -l /dev/console | /usr/bin/awk '{ print $3 }'`
COMPNAME=`hostname`
# Profile Information
## Profile mobileconfig requires two different UUIDs
## for the profile to be setup properly. This is
## separate from the SCEP profile below.
PROFNAME="SCEP Computer TEST"
PROFUUID="C35DB5FE-61A2-4448-8D10-2E6E6EA31846"
PROFID="558B54DB-5FF5-4C8F-A7AB-E64A3693C263"
PAYLOADVER=1
# Company/Organization Information
PROFORG=""
PROFDESC="Used for 802.1X WiFi access"
# SCEP Information
## SCEP URL Endpoint
SCEPURL=""
# SCEP Payload Name
SCEPDISPNAME="SCEP Profile"
## SCEP Name
SCEPCANAME="CA-SCEP"
## SCEP Security Type
SCEPKEYTYPE="RSA"
SCEPKEYSIZE="2048"
SCEPSUBJECT="CN"
## SCEP Cert Renewal Time (Number in Days)
CERTRENEWALTIME=14
# SCEP Profile Identifiers
## SCEP profile mobile config requires two different UUIDs
SCEPPROFUUID="GG69CE46-8AAF-4D74-A8BD-5A13933A1547"
SCEPPROFID="9B95A568-6936-4D48-8C89-4909A5D584B7"
# WiFi Information
# This is to link SCEP with WiFi connection
## Desired SSID
WIFISSID=""
## Desired TLS Trusted Server Name
TLSTRUSTEDSERVERNAME=""
## WiFi Profile Identifiers
### WiFi profile mobile config requires two different
### UUIDs for the profile to be setup properly.
WIFIPROFUUID="F04E7E9D-3B46-422E-B36E-DF79787CD9DC8"
WIFIPROFID="6FC860B4-2166-48C8-8558-A6EFECDC24F7"
### Profile Name
WIFIPROFNAME=""
### WiFi Proxy PAC URL
WIFIPROXY=""
### WiFi TTLS Inner Authorization Type
WIFITTLSINNERAUTH="MSCHAPv2"
### Preferred WiFi Encryption Type
### WPA is WPA2
WIFIENCRYPTIONTYPE="WPA"
### If a computer is using a provisioning network
### that is different than the production network,
### insert the provisioning network in this variable
### and it will be removed from the computer network
### list at the end of the script.
NONDESIREDSSID=""
# FQDN of current computer
FQDN=""
# SCEP service account username and password
USER=""
PASS=""
# cURL request for SCEP
HTTP=`curl -s --ntlm -u $USER:$PASS $SCEPURL`
# Console Log to ensure that the response is received
# properly from the SCEP server
MSSCEPCERT=`echo $HTTP | awk -v FS="(<B> | </B>)" '{print $2}'`
MSSCEPCHALLENGE=`echo $HTTP | awk -v FS="(password is: <B> | </B>)" '{print $3}'`
## Console Log the above returns
echo "SCEP: $MSSCEPCHALLENGE"
echo "SCEPKEY: $MSSCEPCERT"
# SCEP XML mobileconfig payload
# which has the dynamic variables listed above
template="<?xml version='1.0' encoding='UTF-8'?>
<!DOCTYPE plist PUBLIC '-//Apple//DTD PLIST 1.0//EN' 'http://www.apple.com/DTDs/PropertyList-1.0.dtd'>
<plist version='1'>
    <dict>
        <key>PayloadUUID</key>
        <string>$PROFUUID</string>
        <key>PayloadType</key>
        <string>Configuration</string>
        <key>PayloadOrganization</key>
        <string>$PROFORG</string>
        <key>PayloadIdentifier</key>
        <string>$PROFID</string>
        <key>PayloadDisplayName</key>
        <string>$PROFNAME</string>
        <key>PayloadDescription</key>
        <string/>
        <key>PayloadVersion</key>
        <integer>$PAYLOADVER</integer>
        <key>PayloadEnabled</key>
        <true/>
        <key>PayloadRemovalDisallowed</key>
        <true/>
        <key>PayloadScope</key>
        <string>System</string>
        <key>PayloadContent</key>
        <array>
            <dict>
                <string>$SCEPPROFUUID</string>
                <string>com.apple.security.scep</string>
                <string>$SCEPPROFID</string>
                <string>$SCEPDISPNAME</string>
                <string/>
                <true/>
                <dict>
                    <key>Name</key>
                    <string>$SCEPCANAME</string>
                    <key>URL</key>
                    <string>$SCEPURL</string>
                    <key>Challenge</key>
                    <string>$MSSCEPCHALLENGE</string>
                    <key>Key Type</key>
                    <string>$SCEPKEYTYPE</string>
                    <key>Keysize</key>
                    <integer>$SCEPKEYSIZE</integer>
                    <key>SubjectAltName</key>
                    <dict/>
                    <key>Subject</key>
                    <array>
                        <array>
                            <array>
                                <string>$SCEPSUBJECT</string>
                                <string>$FQDN</string>
                            </array>
                        </array>
                    </array>
                    <key>CertificateRenewalTimeInterval</key>
                    <integer>$CERTRENEWALTIME</integer>
                </dict>
            </dict>
            <dict>
                <string>$WIFIPROFUUID</string>
                <string>com.apple.wifi.managed</string>
                <string>$WIFIPROFID</string>
                <string>$WIFIPROFNAME</string>
                <string/>
                <true/>
                <key>HIDDEN_NETWORK</key>
                <false/>
                <key>SSID_STR</key>
                <string>$WIFISSID</string>
                <key>EncryptionType</key>
                <string>$WIFIENCRYPTIONTYPE</string>
                <key>PayloadCertificateUUID</key>
                <key>AutoJoin</key>
                <true/>
                <key>AuthenticationMethod</key>
                <string/>
                <key>Interface</key>
                <string>BuiltInWireless</string>
                <key>ProxyType</key>
                <string>Auto</string>
                <key>ProxyPACURL</key>
                <string>$WIFIPROXY</string>
                <key>EAPClientConfiguration</key>
                <dict>
                    <key>AcceptEAPTypes</key>
                    <array>
                        <integer>13</integer>
                    </array>
                    <key>TTLSInnerAuthentication</key>
                    <string>$WIFITTLSINNERAUTH</string>
                    <key>UserName</key>
                    <key>TLSTrustedServerNames</key>
                    <array>
                        <string>$TLSTRUSTEDSERVERNAME</string>
                    </array>
                </dict>
                <key>SetupModes</key>
                <array>
                    <string>Loginwindow</string>
                </array>
            </dict>
        </array>
    </dict>
</plist>"
# Create the mobile config from the template above
echo $TEMPLATE > /tmp/scep_computer.mobileconfig
# Import the above created template
/usr/bin/profiles -I -F /tmp/scep_computer.mobileconfig
# Check if the mobile config is found in the Profile list
isFound=`profiles -P | grep $PROFID`
if [[ ! -z $isFound ]]; then
    echo "Profile Successfully Added"
# Remove provisioning network from computer network list
if [ -z $NONDESIREDSSID ]; then
    sudo /usr/sbin/networksetup -removepreferredwirelessnetwork "en0" $NONDESIREDSSID
# exiting script
  • August 23, 2017
This sure took some time but we did it!
kid
  • August 23, 2017
Appreciated, but so would some guidance on which fields need to be filled and notes on gotchas when deploying.
  • August 23, 2017
@joshuasee I know Bryan is working on getting comments added to explain all the fields.
  • October 24, 2017
@joshuasee
Not sure if this updated version helps with some of the issues you saw in the original. Let me know if there are other things that need to be updated.
  • November 27, 2017
I'm currently working on server config issues that got exposed in testing, but this script has already been useful. Why is FQDN not set? Is this expected to be provided by Casper or should I use something like FQDN=$(/usr/bin/nslookup $(/bin/hostname) | /usr/bin/sed -n s/Name:.//p); ? Also, is the SCEP URL expected to be in the format of https://your_ca.example.com/certsrv/mscep_admin/ ?
  • January 2, 2018
I am also interested in this as well...
