Anyone got any info on this?
We had an external IP Range pen test done and this vulnerability was found in JAMF jQuery a JavaScript library. It makes things like HTML document traversal and manipulation, event handling, animation and Ajax much simpler with an easy-to-use API that works across a multitude of browsers.
Any help or guidance is appreciated
Maybe try https://www.jamf.com/security/vulnerability-disclosure/ instead....
@boberito Thanks for this, I will log it when I have more details, however, I am unsure on what this impact is.
Do you mean this one: https://nvd.nist.gov/vuln/detail/CVE-2012-6708 ?
our security scans detected it while running 10.15.1 but it seems no to be fixed yet. It was already referenced as Product Issue PI-007381, not sure if there's been an update on this already.
