Jamf Admin 10.7.1 with Mojave - not allowing Printer uploading
  • October 24, 2018
  • 4 replies
  • 28 views
Forum|alt.badge.img+20
I cannot upload a printer using Jamf Admin 10.7.1 with Mojave. Has anyone else encountered this? I am able to add Dock items.
when i click to 'Add Printers' nothing happens, when i double click 'add printers' the drop down quickly appears and dissapears (when this happens i can see that no printers are listed).
I have to go back to a Sierra system with Jamf Admin 10.7.1 and upload the printer from there.
dcollings
  • November 6, 2018
I was just reading through the Jamf release notes. It seems there's a known issue - [PI-005676] In Jamf Admin, you cannot add printers using a computer not enrolled in Jamf Pro. Is it possible that your Mojave machine is unenrolled?
  • November 6, 2018
Before jam pro I always Uploaded printers from an unenrolled computer, so I guess now that's changed. I'll try it now from an enrolled computer
wnazari
  • March 1, 2019
Hi -
Please try the following:
  1. Close Jamf Admin
  2. Open Terminal and run:
sudo touch /Library/Preferences/com.jamfsoftware.jamf.plist
  1. Open Jamf Admin, and add a Printer
  • September 25, 2019
Any reason why this wouldn't work pulling from a Yosemite machine? I click "Add printers" I'm prompted for my password and then nothing. If I hit the "Add printers" button again, a window pops up, but none of my 6 printers are listed there and then the window retracts before I can do anything else.
UPDATE I just upgraded to Mojave cause I was on a time crunch, and was able to import the printers now. I had previously created the blank plist, but no dice. So for future reference, this doesn't seem to work with Yosemite and I'm running JAMF Admin 10.15.0
