I've had three users in the past week and a half whose machines were rendered inoperable following installation of the 10.2.6 combo update. The updates were pushed via an update policy in JSS. In each case, the laptop was powered off when the user arrived. On powering up the machine, they receive a black screen that "critical software updates are required." I tried to connect the machines to wi-fi, but received messages that the machines couldn't connect. Ultimately I had to connect a USB-C Ethernet adapter to get the updates downloaded and then the machines successfully booted. Has anyone else had a problem with these updates?
Any reported issues installing 10.12.6 updates on 2016 MacBook Pros?
