Command line to give Search Policy from Directory Utility?
  • March 11, 2020
  • 44 views
Looked at dsconfigad hoping it would point upward to dsconfig.
Looked at dscl which I think just lists them in alphabetical order.
Looked at odutil which seems to only list connections and statistics.
Any help appreciated.
Best answer by mfcfadmin
dscl /Search -read / CSPSearchPath
That was buried under a rock.
  • March 11, 2020
  • December 15, 2022
Thank you!   It seems so easy and yet it took a while to find this again...  It turns out the Internet is a big place...
  • December 16, 2022
In an attempt to be helpful, here is what I did with this information:
I created an extension attribute -
#!/usr/bin/env zsh RESULT="" authSearchPolicy=$(dscl /Search -read / SearchPolicy | awk '{print $NF}' | awk -F':' '{print $NF}') if [ "$authSearchPolicy" = "LSPSearchPath" ]; then RESULT="local" fi if [ "$authSearchPolicy" = "NSPSearchPath" ]; then RESULT="auto" fi if [ "$authSearchPolicy" = "CSPSearchPath" ]; then RESULT="custom" fi echo "<result>$RESULT</result>"
And I used this bit of shell script to change the Directory Services configuration in the ways I wanted.
#!/usr/bin/env zsh # Change it from Custom to Local searchPathCheck=$(dscl /Search -read / SearchPolicy | grep "CSPSearchPath") if [ "$searchPathCheck" != "" ]; then dscl /Search -change / SearchPolicy "dsAttrTypeStandard:CSPSearchPath" "dsAttrTypeStandard:LSPSearchPath" echo "Switched from the Custom Search Path to Local Search Path in Directory Services Authentication." searchPathCheck="" fi
And here are some notes I captured during testing.
# Key = SearchPolicy # Value options: # dsAttrTypeStandard:CSPSearchPath = custom search Path # dsAttrTypeStandard:LSPSearchPath = local search path # dsAttrTypeStandard:NSPSearchPath = automatic search path # delete AD from the custom search path # dscl /Search -delete / CSPSearchPath "/Active Directory/YOURDOMAIN/All Domains"
