Remove Application from multiple locations on computer
  • March 12, 2020
  • 8 replies
  • 58 views
We have a application that we are trying to remove from all managed computers (HipChat). It can live in /Applications or ~/Applications or pretty much anywhere. I did a basic script to remove it from /Applications but lots of machine still report having it installed. Any pointers on scripting to search the drive to find the App and remove all copies from all places?
  • March 12, 2020
Are you also removing the receipt from when it was initially installed?
  • March 12, 2020
I have not been, basically just a rm pointed at the .app in /Applications. I know it is still installed in some ~/Applications even after the policy to remove it has run, because its not looking there. So it continues to report in Inventory and the Policy still shows in self service, which is a little annoying for users.
  • March 13, 2020
Any reason you don't just set up a Restricted Software policy and select the option, "Delete Application"? I was under the impression that it did not discriminate based where the application was launched from.
  • March 13, 2020
Restricted Software should help like mentioned above.
In the event that you want to more proactively find and delete the application, you could consider using a script that uses mdfind (faster) or find (slower but sometimes more accurate) to locate the app and delete it.
  • March 13, 2020
Thanks for those. I'm not sure the restricted policy will work because the app never gets launched. I will test it to see how it may do what we need. Its the scripting of the find that I struggle with, but that's what testing is for. Thanks again.
  • March 13, 2020
while read result; do
    /bin/rm -R "$result"
done < <(/usr/bin/mdfind 'kMDItemKind == "Application" && kMDItemFSName == "HipChat.app"')
Something like that when using mdfind might work
  • March 13, 2020
Things like this make me wish I knew more scripting. Thanks much.
donmontalvo
Forum|alt.badge.img+36
  • March 14, 2020
Due to the recent zero day vulnerability, we had to remove any/all copies of Google Chrome that was not at the desired version or higher.
Would run this script in its own policy (target all computers) as a clean up script to remove copies not in /Applications/Google Chrome.app path.
A second policy enforces /Applications/Google Chrome.app path, where if you have it but it isn’t the right version (or higher), we replace it with the right version.
Replace "COMPANY" with your company name.
GOODPATH="/Applications/Google Chrome.app"
BUNDLEID="com.google.Chrome"
SEARCHDIR="/Library/Application Support/COMPANY/SearchResults"
SEARCHFILE="$SEARCHDIR/Removed-Google-Chrome-$DATESTRING.txt"
DATESTRING=$(date +%Y%m%dT%H%M%S)
# Create folder if it doesn't exist
mkdir -p "$SEARCHDIR"
# This function finds all apps with CFBundleIdentifier "$BUNDLEID", but ignores
# `/Applications/Google Chrome.app` path. This method of searching ensures
# accurate result whether the app was moved or renamed.
function searchCommand() {
    mdfind kMDItemCFBundleIdentifier="$BUNDLEID" | grep -v "$GOODPATH" > "$SEARCHFILE"
# This function removes all copies *only* if not in correct path.
function removeCommand() {
    xargs -I{} rm -r {} < "$SEARCHFILE"
searchCommand
removeCommand
